Hybrid Battery Temperature Getting Warm
Discussion in 'Newbie Forum' started by Umair90, Apr 29, 2020.
  1. Umair90
    Umair90 Junior Member
    34
    Pakistan
    Hey there. Hope u all doing great.
    Recently I downloaded Dr. Prius App and found this error.
    “Battery Temperature getting Warm”
    I heard the Hybrid Fan noise and it’s working i believe.
    What will be the issue? Experts plz?
    I’m getting very low millage these days.
    Car Millage: Approx 65,000Km
  2. Mendel Leisk
    41,860
    I used to have a ScanGauge II hooked up, pretty much constantly, and the highest I recall was around 45C (113F), in stop-and-go conditions, but it wasn't that hot/extreme. I'd suspect 50C (122F) would occur easily, stop-and-go in very hot climate.
    I would start by checking the condition of the hybrid battery fan: they can get clogged with lint and dust. There's a fan cleaning video, by @NutzAboutBolts, linked in this thread:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    (video #21)
    I wouldn't bother removing the rear seat bottom though, it's just more work. There's one bolt (12mm socket size) you need to remove. If you push apart the seat bottom and back portions, just below the fan inlet grill (on seat back), the bolt is in behind there, reachable with an extension on a ratchet wrench. Just be careful not to drop it.
  3. Umair90
    34
    Pakistan
    Thanks Mate. Let me check the fan in morning then. Hope it’s clogged or dirty, but not any other fault.
  4. Umair90
    34
    Pakistan
    Any yeah, the temperature in my region is around 91•F these days. Maybe 121•F is normal. Maybe not!
  5. Umair90
    34
    Pakistan
    Hey thanks for the tip. I cleaned the fan. Fan Blades was black Dur to dirt but now it’s cleaned and the temperature is gradually decreased and the life Expectancy Test shows the good health (83.65%). Previously it was showing 65%.
    Plus i cleaned the Battery Rusty points.
  6. Mendel Leisk
    41,860
    When I had 45C, I was also monitoring fan speed, and it got up to "4", and I believe there are 6 speeds? So the car's computer was not overly alarmed.
  7. Umair90
    34
    Pakistan
    Sorry I didn’t get you. How to check Fan speed?
  8. Mendel Leisk
    41,860
    I was using a scangauge II with extra "gauges" code added (called XGauge), for hybrid battery temp and fan speed.
    I had it connected constantly, but unfortunately it seemed to be the source of communication errors, perhaps due to constant weight on OBD port, so I discontinued use.
  9. Umair90
    34
    Pakistan
    Oh i see.
  10. AzusaPrius
    AzusaPrius Senior Member
    2,224
    930
    The app is showing atleast 3 bad cell modules. Block 5, 7 and 9
    The second shows block 13
    7 is for sure bad and must be replaced.
  11. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    1) I don't think you can make that conclusion based on only 2 screen shots.
    2) The voltage differences between the highest and lowest blocks are well within an acceptable range in both instances. In the first instance, the voltage difference is .10V. In the 2nd, it is .14V. For the Battery ECU to throw a code, that difference has to be above .3V on a consistent basis, I believe.
    Based on the admittedly limited information provided, his battery seems to be in good condition and well balanced.
  12. AzusaPrius
    2,224
    930
    The app is spot on to help you find bad modules, I use the app and it showed for me block #12 was bad. I opened the hybrid up and and tested all modules and in fact #12 block is bad. So based on that I can tell him the cell module is bad.
  13. Umair90
    34
    Pakistan
    Yeah i agree with you
  14. Umair90
    34
    Pakistan
    Okay let me test each cell health manually. I will visit workshop and Update you soon
    AzusaPrius and davecook89t like this.
