Hybrid Battery Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Reloadwin, Oct 29, 2012.
  1. Reloadwin
    Reloadwin New Member
    Ballwin, Missouri
    Hello all. I have tried to search online ext google and here as well. My question is can you upgrade the main Hybrid battery in the Gen II Prius NiMH battery to the Li-ion battery?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Short answer, no.
    The main issue is the Gen II battery management system was designed for NiMH. The nickel metal hydride battery is maintained between 40% to 60% charge most of the time.
  3. Alice Mya
    Alice Mya Junior Member
    42
    In that case can you upgrade the Gen III prius 2012 battery from NiMH battery to the Li-ion battery?
  4. jadziasman
    1,355
    487
    District 6
  5. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    I believe the Auris hybrid in the UK has an Li battery while the US version has Nimh but the control hardware is probably different.
  6. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    With sufficient time, money and technology, one can upgrade anything to anything else. I have a friend who upgraded a 1969 VW Bug to run on Li-I-Po batteries (see Corbin's Treehouse » Plug Bug).
    Perhaps you're asking "can I simply swap battery packs"? That's been answered... not without swapping the battery management system.
    The question you should be asking is... "how much needs to be swapped?" The answer to that question will take quite a bit of digging to find.
  7. veggieranger
    veggieranger Junior Member
    37
    Peachtree City, GA
    Most of the Lithium chemistry battery options I've seen on a Prius are battery range extenders. There are a few Prii in Atlanta that have systems installed with LiFePO4 battery packs but they don't replace the HV battery pack. They just complement it and extend the battery range of the car.
    Data Daedalus likes this.
  8. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
  9. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Another short answer: Yes.
    Already one year ago, I upgraded my 2008 Prius II with a 16.5 kWh battery pack. It includes an Orion BMS.
    I have a hard time to remember when I went for the last time to a service station.
    I recently went from Brussels all the way trough France at highway speed and did not have to fill up.
    Kind regards,
    Walter
  10. bisco
    49,488
    i went in early october.:(
  11. Needanautomatic
    Needanautomatic New Member
    Dublin Ireland
  12. Needanautomatic
    Dublin Ireland
    Hi Wa Wa,
    I am just wondering what system you upgraded to and what it cost? Thanks
  13. bisco
    49,488
    the 'buy all your parts independently and figure it out yourself' system. parts cost = $10,000. :)
  14. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    here is a price list from one shop that does those types of upgrades
    Gen 2 Prius (2004 - 2009)
    4kwh Pro MPLG*
    $9,750 Installed (around $4,000 after tax rebate for CO residents)
    Up to 15 miles all EV range around town
    Top speed over 50mph in EV mode
    100MPG in blended mode for 20-30 miles per charge
    Spare tire accessible
    Gen 2 Prius (2004-2009)
    10kwh Pro MPLG*
    $12,250 Installed (around $7,000 after tax rebate for CO residents)
    Works on any Gen2 Prius, even high mileage cars with Hybrid battery “worn out”
    Up to 20-40 miles all EV range around town
    100MPG in blended mode for 60-80 miles per charge
    Includes rear suspension upgrade
    Optimized regen capture for mountain decents
    source
    Upgrades | Boulder Hybrids
    #14 vvillovv, Nov 4, 2014
  15. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Sounds interesting, where did you have your car upgraded? its because i live in Germany, and how much did it cost?
    i have the Gen III maybe its possible to do the same upgrade on this model, do you know if its possible?
  16. bisco
    49,488
    he did it himself. with a friend.
  17. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Bisco is right. It is a D.I.Y.- system assambled in Eindhoven. Parts alone: € 10.000.
    It transformed my 2008 Prius to a flying carpet.
    Where are you living in Germany?
    Friday I drive to Heidelberg.
    regards frm Brussels.
  18. bisco
    49,488
    if you click on wawa's avatar, you can go to his home page and find his thread on installation, it's fascinating.
    Christian_cool likes this.
  19. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Also this: wheter or not it is possible on the P3 depends on Orion = the BMS maker.
  20. bisco
    49,488
    fyi, there is a new comer today posting chinese diy complete 4 kWh kit for gen III. $3,800. eric dong is the member.
