Hybrid Battery
Discussion in 'Gen 2 Prius Main Forum' started by Rxmxsh, Mar 17, 2007.
  1. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    I've had my Prius for 2 weeks today. Last night, my hybrid battery dropped to 1 bar below half. It stayed that way most of the time, until after dinner on the way home. On the way home it went back to nearly a full charge (minus one bar). All the driving was done in the city, normal circumstances.
    What's the lowest you guys have seen your hybrid battery meter?
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) Lowest was TWO BLUES so far on my '07 touring Edition owned since November '06. I did see ONE PURPLE several times on the '04 Prius I drove for over two years. So far NO GREENS on my '07 - did see GREENS on the '04 several times.
    I rarely look at the ENERGY display - just let the Prius' computers take care of that.
    My 2¢... for what it's worth.
  3. Tideland Prius
    16,127
    2 purple bars is the lowest I've seen. I don't think I've ever seen 1 purple bar.
    I've seen 8 bars on numerous occasions.
  4. pinball
    pinball New Member
    121
    Surrey UK
    <div class='quotetop'>QUOTE(Rxmxsh @ Mar 17 2007, 07:25 PM) [snapback]407482[/snapback]</div>
    I've had one purple bar about 3 times since Nov 05
    I also find that if I start out in the morning in EV mode and say 4 or 5 bars, as soon as the ICE kicks in it eats away at those bars and then after a mile or so starts to replace them - so I try to use them all up in EV mode until the ICE is forced to start up.
    A colleague at work has the Gen 1 Prius which she bought in 2002 - and just had the hybrid battery replaced free of charge by a Toyota GB recall....she didn't know why but I'd guess it was done under the warranty.
  5. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Under "regular" operating conditions, one pink bar. That was inch-at-a-time gridlock during hot weather for the Hurricane Rita evacuation out of Houston, TX. (That was an amazing experience, BTW.)
    Under not-so-normal operating conditions, I've had it down to zero. Yeah, I ran out of gas once. Yeah, I knew it was possible. Yeah, I was dumb. I had been using a trip odometer to track how far I could go between "last pip" and "low fuel" warning -- but on this one trip it was about 1/2 of what I had been previously getting and I was in a stretch of road with NO fuel stations.
    Thankfully, the system protects the battery... I turned off everything but headlights (it was dark) and slowed to 30mph trying to get as close to the next highway exit as I could. I made it about 1.8 miles and then the battery was empty, no arrows on the energy screen, and the accelerator was floored. :) Once stopped, my only choice was neutral or park.
    That was the first (and last!) time I run out of gas in a car. But the Prius can handle it if it happens -- Yeesha's been operating juuuuust fine.
  6. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    I've been down to one bar a couple of times while sitting in a traffic jam.
  7. iaowings
    iaowings New Member
    450
    1 red/ purple bar.
  8. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    <div class='quotetop'>QUOTE(IAO @ Mar 17 2007, 10:31 PM) [snapback]407737[/snapback]</div>
    Going up Tioga Pass in Yosemite, a single purple bar was the lowest. I was a bit worried about the low reading, but I figured some other warning light would appear if there was a problem. I got more worried as on the down hill all green bars lit up for a long time. I was worried about overcharging.
    On a long downhill (I'm talking about thousands of feet drop without level or uphill) as is the case over Tioga pass and the drop into Death Valley and the engine is working hard braking, what happens to the energy regenerated beyond the batteries capabilities to hold it? The grades are so steep that I was trying to decide the lesser of two evils: over using the brakes or overcharging the batteries.
    Any thoughts? :huh:
    Lee
  9. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I had one purple bar after going up the parking garage at the hospital. but it charged itself on the way back down.
    also did the same thing when I had the A/C on while I had the car parked.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Two purple bars for me, on my 2006.
    Tom
  11. wrprice
    415
    308
    Houston, TX
    Four Touring
    <div class='quotetop'>QUOTE(Gadgetdad @ Mar 18 2007, 01:30 AM) [snapback]407753[/snapback]</div>
    The car will switch to physical (friction) braking when it decides that any additional regen braking would charge the batteries over its limit. You don't really get a choice in the matter; the car will protect itself.
    However, you can use the engine braking mode ("B") to give the car an alternative to switching to friction brakes. This is the best option for an extended downgrade since it doesn't result in overheated brakes. In this mode, the ICE will spin (without fuel, if possible) to add drag to the wheels.
  12. Gadgetdad
    462
    Modesto, California
    <div class='quotetop'>QUOTE(wrprice @ Mar 19 2007, 09:42 PM) [snapback]408764[/snapback]</div>
    Thanks, for the info. I was in the "B" mode! That little ICE was spinning like a top. Friction braking and the "B" mode were needed to keep from finding out what the terminal velocity is for a Prius! :eek:
    Lee
  13. Gadgetdad
    462
    Modesto, California
  14. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    I seem to remember reading a magazine review of the 01-03 type Prius- Car and Driver or similar. They went flat-out as fast as they could up a mountain pass and eventually depleted the battery to the point where the computer intervened. I seem to remember that they said a turtle icon appeared on the screen (no I am not kidding) and that it continued up the mountain, albeit more slowly, using the ICE only.
    Seems like under more normal usage conditions this won't happen, though.
    I did also read about the very first (Japanese-market) Prius having quite a bit of that trouble when later exported to countries with wide-open spaces. Used cars from Japan are pretty commonly exported to Australia, and Australian users experienced this quite a bit in that first-generation car. They added power to the ICE and motor systems since then (first when they brought the Prius to the US, and again with the '04 redesign) so it shouldn't be easy to deplete by going flat-out up a mountain anymore.
    I've seen one purple bar while crawling in heavy traffic in downtown Atlanta before. Shortly thereafter the ICE fired up for a few minutes to recharge the battery.
  15. Tideland Prius
    16,127
    <div class='quotetop'>QUOTE(wyounger @ Mar 24 2007, 12:21 PM) [snapback]411563[/snapback]</div>
    The turtle icon was on the 97-03 Prius. The reason for that is to tell the driver that the battery will no longer be able to assist the motion of the vehicle and so you will see reduced performance.
