Hybrid code p0b60 -123
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ensol, Nov 27, 2015.
  1. Ensol
    Ensol Junior Member
    27
    Uk
    Hi my vehicle has developed a problem with the hybrid system! The p0b60-123 is showing! Something to fo with battery h sensor voltage being low! Would realy appriviate help! Mileage on vehicle is 160000 miles. Thanks
    Hi
    51,140
    does it run okay and get the same fuel economy?
  3. Ensol
    Ensol Junior Member
    27
    Uk
    No it wont start
    51,140
    what are you using for a code reader?
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The DTC code for P0B60-123:
    P0B60-123
    Hybrid Battery Voltage Sensor "H" Circuit Low
    1. Battery smart unit
    2. HV battery assembly
    The H circuit would be for battery module pair 7, if I am interpreting the Repair Manual correctly. It says that the voltage is less than about 2.5V, or an open circuit. Normal voltage would be in the 15V range.
    Each battery module pair has a voltage sensing wire that goes to the Battery Smart Unit for monitoring voltage of module pairs and voltage difference between module pairs. Either you have a broken sensor wire or a defective Battery Smart Unit.
    If you are comfortable working around 220VDC you could open the HV battery case and verify the H sensing wire connection to the Battery Smart Unit and determine the problem.
    #5 jdcollins5, Nov 30, 2015
  6. Ensol
    Ensol Junior Member
    27
    Uk
    Thanks for your help
    jdcollins5 likes this.
  7. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Good luck. Keep us posted.
  8. dklayton0213
    dklayton0213 Junior Member
    35
    16
    Hattiesburg MS
    I have the same issue except a different sensor wire. How do I go about verifying the connection?
  9. MoeSeth
    MoeSeth New Member
    Myanmar
    Screenshot_2021-11-29-22-58-36-40_4c9d9310924d052fe4000da8e14e845e.jpg P0B60 HV ECU Replaced.
    All good normal.
