Hybrid Control ECU location?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mcrogers22, Jan 25, 2019.
  1. Mcrogers22
    Mcrogers22 New Member
    Tempe AZ
    2005 Toyota Prius
    Code is U0111 with no sub code.
    Where is the Hybrid Control ECU located and are all 2nd gen HV Control ECU’s compatible? The ECU’s forsale online all say for 06-09. Since mine is 05 I just want to make sure it’s going to work if I put an 08 ECU in it as I have a parts car.
    Haven’t rulled out the Battery ECU just yet but want to be able to fix the issue once I start working on the car.
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    For the sub codes (INFs) you will need to scan with a hybrid compatible OBD2 device, or a mini-vci cable with techstream ($20 or less).
    Here is the workup for the following DTC/INFs : U0100/212, U0100/530 U0111/208, U0111/531, U0129/220, U0129/222, U0129/528, U0128/529, U0131/433, U0131/434, U0146/435 :
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/0100211.pdf
    Here is an image that might help you locate the ECU in question :
    Raytheeagle likes this.
  3. Umerpk
    Umerpk Junior Member
    24
    Pakistan
    Guys what is the location of Intelligent Parking Assist ECU in Japanese Prius 2006?
  4. Scott Caputo
    Scott Caputo Junior Member
    37
    Los Angeles
    I changed the hybrid vehicle control ECU. Do I need to reprogram it?
  5. ContraAl
    ContraAl Junior Member
    Sacramento
    I know this is an old post but I had the same question as Scott.
    The answers is sort of.
    If you replace the Hybrid Vehicle Control ECU the donor unit will have a VIN. For this you will need Techstream or Autel or some other tool. Updating the VIN with these tools can be done offline. Once the VIN is transferred, do a "handshake" process and you should be good to go.
    SFO likes this.
