Hybrid Display Burn in
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by p626808, Mar 30, 2011.
  1. p626808
    p626808 New Member
    292
    Noticed my hybrid display is really starting to burn in with the hybrid display indicators and the LKA and DRCC images. It is most noticible when I switch to the consumpsion by the minute display.
    Any thoughts?
    I have the 100K warranty.. was thinking of seeing what the dealer/toyota care has to say about it.
    I have 64K on the car right now.
    Scott
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    My Prius is only a few months in and I'm already seeing it. Oh well...
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I don't see a hint of burn-in on our V at 17.5K. We have used DRCC & LKA less than 20% of those miles. How many miles do you have on your V and do you use DRCC & LKA most of the time. Keep us posted on what Toyota says regarding replacing your display under warranty.
  4. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    isn't the hybrid display LED? if I remember correctly the burn-in was on CRT displays and LED displays do not exhibit this because the burn-in on CRT's was do to the phosphorus coating on the inside of the tube and LED's are light driven
  5. Hokeysmoke
    Hokeysmoke Junior Member
    76
    Oregon
    Vacuum Fluorescent Displays use phosphors just like plasma screens and CRTs.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    post deleted
  7. tumbleweed
    4,067
    687
    Eastern Oregon
    Is that what the Multi-Information Display is? I thought it was an LED display but I can't find a reference.
    According to some of the flat panel TV forums LCD or LCD/LED displays can suffer image retention but I don't think it is permanent the way image burn on a plasma display could be.
    Has anyone noticed if the retained image on the MID screen fades if the DRCC/LKA are left off for a while?
  8. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    You can show us a pic if you want, but some uneven wear in the screen is normal, mine does it and has since day one. Their was another thread about this and it was concluded that it was normal for the thype of display.
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Thanks for the heads up regarding display burn. I'd love to get an update from you if you take this issue to your local dealer. I've not noticed any image retention, burn or whatever, but I only have low 20K miles.
  10. p626808
    p626808 New Member
    292
    HAve not done anything yet.. have 80K now.. will try to get to the dealer soon.
  11. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Here is a paragraph from New Car Features TechDoc manual:
    - A Vacuum Fluorescent Display (VFD) which has a stable operating characteristic and emits a very bright light with clear contrast is used to indicate the vehicle speed, fuel, instantaneous fuel consumption, shift position and multi-information display.
