Hybrid engine check engine light on! 2006 Prius still runs. What's happening?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrea L Chase, Nov 22, 2021.
  1. Andrea L Chase
    Andrea L Chase New Member
    Driving along this evening when both check engine and check hybrid engine lights came on. Managed to get the three blocks home where I turned off car, waited and turned it back on. Light were still on. Any ideas??
  2. Andrea L Chase
    Should add that it has 41,000 miles on it and had auxiliary battery replaced last August.
  3. JC91006
    16,749
    8,555
    It seems as though your car isn't driven much. It could very easily have a low charge on the 12v battery. Those lights could point to a number of things on the car, just can't guess at it. You would need to read the codes from a mechanic or a friend that has the equipment to read them.
    SFO likes this.
  4. Andrea L Chase
    Thanks so much! It's so disconcerting to have both check engine lights suddenly go on! I have downloaded Dr Prius, but need to get the Bluetooth thingy (technical term ). Any guidance on getting the most out of it gratefully recived!
    The funny thing is that if parking were easier in San Francisco, it would probably have half that mileage! Sooo much circling to find a spot!
