Hybrid Engine Shaking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Florida_Man, May 18, 2021.
  1. Florida_Man
    Florida_Man New Member
    Has anybody else experienced this? I took my Prius to a local mechanic, and he told me to take it to someone who specializes in hybrids because they don't have the proper equipment. The hybrid engine is definitely the cause of the shaking, though.
    2012 Prius (base) with 170k miles. My engine oil is good, and I have no leaks or other visible problems.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,963
    4,709
    Texas Hill Country
    Head Gasket especially if it goes away in a minute or so. Otherwise a misfire due to a plug, coil or injector.
    Worse case hg:
  3. Mendel Leisk
    38,709
    Common issue. EGR system and intake manifold overdue for cleaning. Toyota has their head firmly in the sand on this. Some would say elsewhere.
    More info:
    Bad Flywheel | PriusChat
  4. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    EXACTLY!
    You can check this by taking out EGR connector for few seconds, the engine will stop shaking...
    But will light the DTC with some errors...
  5. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    So what happened on this?
