hybrid information screen went out
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hikingslo, Feb 2, 2011.
  1. hikingslo
    hikingslo Junior Member
    Central Coast California
    We bought our 2011 2 weeks ago today and the hybrid information screen went out.:( Is this happening alot and are those it is happening to experiencing any other problems? Any info would help. Taking it to the dealers tomorrow. Thanks!
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    You probably accidentally turn the screen off.
  3. MelissaAnne
    MelissaAnne New Member
    265
    52
    Louisiana
    LOL....fail
  4. hikingslo
    I wish it was turned off. hold the display button and nothing... no settings menu. when i talked to the service dept yesterday i got the feeling this isn't the first time they have heard about this. I called to make sure i wasn't missing a fuse somewhere and he said it wasn't a fuse and and that i needed to bring it in. thanks for any info
  5. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    It's the dimmer dial, not a button. They're asking to make sure you didn't turn it down by accident.
  6. peterjmc
    917
    188
    Clarksburg, MD
    If you use the funcitons on your steering wheel you can enable the setting to turn off the hybrid display.
  7. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Yes, but if you have the headlights on and the dimmer switch all the way down you're not going to be able to see anything regardless of that button.
    Also check for any paper, receipt, etc. that fell into the dash. That might be blocking the display.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I think you discovered the "Secret Mode"....EV, ECO, POWER,-normal- and "Flyin Blind"!
    Hey, it's all under warranty...so whether it's simply something to learn about the system or you need repair...it's all good.
  9. hikingslo
    It's not the dimmer switch otherwise i wouldn't be able to see my speedometer, likewise with paper covering the projection screen. The dealer couldn't figure it out today after 6 hrs. They have to talk to somebody back east (who couldn't get to work today because of all the snow) to start a case. Will take it back monday and see what happens. Will keep posting updates and any info is appreciated!
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    It hasn't happened a lot but we have had several posts going back to the first Gen3 cars. It has usually been the right half of the display (MID) that goes but some have lost the left part where the speedometer is as well.
  11. hikingslo
    Thanks for the info. I haven't been able to find much on the subject so it must be pretty rare. Maybe i should try the lotto!
  12. Spenumatsa
    Spenumatsa Junior Member
    77
    Nashua, NH
    The right side of the MFD went off on my 2010 Prius last week and the dealer replaced it with a new one. It seems there are a handful of this issue on 2010 Prius model.
  13. hikingslo
    Looks like I will finally get the screen replaced tomorrow. :) Driving without the hybrid display takes out alot of the fun!
  14. RX-8
    RX-8 Junior Member
    Charlotte, NC
    Well, that happened to me when my 12volt battery was going down, but after I replaced the battery and drove it for a little bit, the display came right back after I turned on
    #15 RX-8, Nov 12, 2018
