Hybrid monitor not shown in multi-information display
Discussion in 'Prius v Technical Discussion' started by Ohid, Feb 6, 2022.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    My car doesn’t show battery monitor. I am not able to press 'i', when I pressed 'i' it shift to blank page. Red marked in the attached photo. What should I do to show hybrid battery monitor?
    It was shown till yesterday but someone in the Workshop did something wrong. After that it is not working.
    49,371
    hard to diagnose what 'someone in the shop' might have done. try disconnecting the 12v neg for a minute.
    Ohid likes this.
  3. gromittoo
    gromittoo Active Member
    718
    286
    philadelphia
    2013 Prius v wagon
    Was the car moving at the time? The setup menu is disabled if the car is moving, and a blank page is displayed. As for not showing the battery monitor, I suspect that setting might get reset to default if the shop disconnected the 12 volt battery.
    It is possible there is a defective connection to the steering wheel switch, for example the "Clock Spring" is flaky. Did they remove the steering wheel?
  4. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    No, they didn’t disconnect 12v battery.
    Problem is solved. After taking it to the Workshop, they tried to press all the switches of steering wheel. Luckily it is working now but they could not identify which switch helped to back it normal.
  5. bisco
    49,371
    good news!
    Ohid likes this.
