.:: Hybrid Pit • Buena Park, CA • Review ::.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by m3pare, Oct 7, 2017.
  1. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    Forgive me if this is the wrong section to post this in. There isn’t really a California subforum and I noticed most of the Prius modders here are from SoCal. Just wanted to share with you guys my first experience as a customer of HybridPit. I’ve known both Sean and Roger for almost two years now, but I haven’t taken my car to get serviced or repaired by them in the past. I usually try to knock out the simple oil and filter changes at home.
    Long story short, my sister also has a Gen III Prius with just a little over 166k now. A few days ago, she was driving to work when the car suddenly went into a ‘limp’ mode. The car locked itself into B mode and did not let her accelerate to speed the car up. The ‘Check Hybrid System’ warning appeared on the dash along with many other error lights. Thankfully she was driving at a low speed in stop-and-go traffic and was able to let the car coast in B to the side of the freeway.
    As soon as she called me, I began looking for similar symptoms and solutions on the forum. I told her to turn the car on/off 3-4 consecutive times to try and reset the ‘Check Hybrid System’ warning. No dice. Next up, check the 12V battery for any loose connections. Everything was secure. Gas was halfway filled, nowhere near empty. I was stumped and told her to just tow it home so I could take a closer look. At this point, I figured the HV battery had finally taken a dump.
    Once the car was home, I tried to drive it around but the car would lock itself into neutral just a couple seconds after the ICE would turn on. I noticed it was also shaking more violently than usual. I didn’t have an OBD2 adapter to read any fault codes and the car wouldn’t even make it down the street to an O’Reilys to get it scanned. Fantastic. (I ordered one and downloaded Carista same day — I just hit 90k on my 2012 and I’m sure it’ll come in handy.) Anyways, I contacted Sean and asked him if I could have the car towed to Hybrid Pit. Luckily, there was still room for one in the packed shop!
    A few hours later, the car was finally towed over to The Pit. AAA happened to be ridiculously busy that morning and had me wait 3 hours for the next available technician. As I arrived, Roger was there waiting and he began to diagnose the car with a battery tester as well as TechStream. The following code kept pending after multiple resets — P3190 “Poor Engine Power”. Roger tested the fuel pump, and Sean confirmed that was the issue the next day after testing the pump relay and harness.
    With the new fuel pump installed, the car was ready to rock and roll again. But since the car was already at Hybrid Pit, I figured it could use some more TLC with 166k on the clock. I’ve been reading more and more threads on the EGR system carbon build-up issues and I wanted to prevent any future blockage. So I had Sean & Roger give the full EGR system — pipe, valve, and cooler — as well as the intake manifold a good thorough cleaning. I’ll let the pictures speak for itself.
    Finally had some time today to pick up the car and I couldn’t be happier with the outcome. The car drives great! Again, a big thank you to both Sean and Roger of Hybrid Pit for taking care of us. Their workmanship is truly top notch and both guys are very honest and thorough, continuously sending me texts as they went through the car. They stand by their work and won’t try to up-sell or pressure you into getting certain services done all at once. For those without an open checkbook readily available, they’ll also work around your budget and recommend which maintenance items to prioritize.
    I highly recommend any of my friends and fellow PriusChat enthusiasts in the Los Angeles or Orange County areas to contact the guys at Hybrid Pit if you need any work done on your vehicles. From what I’ve seen, most conventional independent shops are one, too afraid to touch a hybrid car, or two, charge a crazy premium to work on a Prius. Hybrid Pit pricing is very reasonable and they work on more than just hybrids! I saw an IS300 getting the transmission rebuilt and an Acura Legend with the motor all torn apart while I was there. Where else will you find 2 bada** full G’s Prius twins hanging out in a parking lot?
    Thanks for looking!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Nice car seat covers, My son would like them in our Prius :).
    Trying to get something setup with Sean for the end of November when we are down there, but he's a little slow to respond to PMs it seems:whistle:.
    #2 Raytheeagle, Oct 7, 2017
  3. ckam1989
    ckam1989 Active Member
    185
    358
    Irvine, CA
    2014 Prius Plug-in
    I agree! Sean and Roger are very professional, honest, quick and precise. The only shop I would trust my baby to.
  4. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    I saw your car there today. I randomly stopped in to (prii) chat with them and order some stuff. Very cool guys.
  5. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Hybrid pit is the best prius shop around....and only one lol
    Montgomery, m3pare and Daigi_ like this.
  6. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    If I didn't live 7 hours away, I'd come. It's gonna be soo cool and I'll be missing out.
    RightOnTime likes this.
  7. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    If only they were in NorCal!!
    Joele3, RightOnTime, Xterra72 and 4 others like this.
  8. Nopho4u
    1,007
    2,061
    Socal son
    A Norcal shop would make sense in the bay with the on slaught on prii in the area
  9. orenji
    orenji Senior Member
    5,884
    3,486
    Just so you all know Hybridpit is more then a repair shop, they also sell JDM accessories/items for the Prius. Check out their website if your not in the area. Join the Hybridpit Family!
  10. m3pare
    679
    1,818
    SoCal (626)
    Thank you again to the HybridPit team!!! The codes C0200 (Front Speed Sensor RH Circuit) and C1235 (Foreign Object is Attached on Tip of Front Speed Sensor RH) popped up on my sisters Prii a few days ago and the VSC, ABS, and TPMS lights were on. Symptoms included no regen braking and a longer depress of the brake until initial bite. The car was still drivable, just a little hard to control in stop-and-go traffic.
    Yesterday, I texted Roger asking if he’s ever dealt with those 2 codes and if I should clean the brake sensor or replace it. He says, swing by the shop later. (y) I get to Hybrid Pit a couple hours later and Roger test drives the car, confirming those aforementioned symptoms. So we take off the passenger front wheel and find our culprit. The brake sensor clip fell out of the chassis hole and was dangling down while the tire probably kept shaving down the wire. Roger gives Sean a call and what do ya know, Sean has a spare at the shop! I got super lucky. :D Now I don’t have to pay a ridiculous amount for a new part at the stealership or take my chances with a cheap aftermarket sensor. ($150+ OEM vs. $25 aftermarket)
    Roger replaced the sensor with ease and I was in an out of there within half an hour. Thanks guys!!! :)
  11. orenji
    5,884
    3,486
    8CF9CA3B-C1B7-4D15-8BA5-5715ACEF6E3E.jpeg Had some work done there last weekend. :)
  12. James Powers
    396
    555
    Bay Area
    Nice! I cant decide between this or a CAI. How do you like this so far? Notice any difference?
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    We all need to just have a Hybridpit BBQ hang out party. Spend time there getting to know the crew, cooking food and relaxing. Ideal is to have it an all day thing, so those of us who work weekends can fit in time.
  14. orenji
    5,884
    3,486
    No real difference I can tell. But the Tom’s front strut bar, amazing!!
    CAI will be the same with no real noticeable difference. But I guess that’s a good thing!
    GTprii, RightOnTime and James Powers like this.
  15. orenji
    5,884
    3,486
    Got some more goodies today! Secret stuff!! :)
  16. MPGESUS!
    MPGESUS! Junior Member
    I got my first package from them last night! I can't wait to stop by.
    orenji, Burna J and James Powers like this.
  17. James Powers
    396
    555
    Bay Area
    I guess by difference I meant sound since we wont see much difference in performance :ROFLMAO::coffee:
  18. orenji
    5,884
    3,486
    No sound change, but then I am running Tanabe exhaust :)
  19. orenji
    5,884
    3,486
    20DD9137-0949-40C8-A96E-BD8F48A45A0E.jpeg A0895150-8A05-43E5-9CE3-C866C4B9ABB1.jpeg 76CCFCE4-D395-43D7-8215-07DE5B31608A.jpeg D38913C7-E8AC-42AA-BED5-DFDB55008F06.jpeg Had the day off today, so I decided to go over to Hybridpit. They were able to squeeze me in and make some changes to my ride today. Thanks again for the great install!! :)
  20. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    orenji likes this.
