Hybrid Radiator Hoses Package: Prius V 2017
Discussion in 'Prius v Main Forum' started by BSA, Apr 6, 2025.
  1. BSA
    BSA New Member
    Arizona
    2017 Prius v wagon
    Hello
    I took my car to get an oil change at the dealership on two times and each time they told me that it was required to change my radiator hose before summer. When I look at the media they provide one picture looks like the regular radiator and the other looks like the inverter radiator…thoughts ?
    the first picture was for October oil change & the second for Februarys oil change the third picture is a description of the recommended service that is for both
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,599
    5,895
    Texas Hill Country
    How many miles since last flush? If unknown drain and fill at a minimum. One pic seems to show a crack in one hose - clean them up and inspect.
  3. BSA
    BSA New Member
    Arizona
    2017 Prius v wagon
    Thank you for the response, I will be doing a coolant flush asap. Which hose is cracked? I’m having a hard time seeing it. I’ve even wiped off the hoses and used a flashlight to see if I can notice a crack or shadow at multiple angles and I’m having a hard time seeing it. I’m not even sure if it’s the radiator hose or the inverter coolant hose(s). Thank you.
  4. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Did you attach the correct photos?
    The radiator in real life looks completely different than the inverter coolant tank.
  5. Air_Boss
    Air_Boss Senior Member
    4,140
    1,154
    New Yawk
    Really? A $1000 money grab?
  6. Mendel Leisk
    40,587
  7. rjparker
    9,599
    5,895
    Texas Hill Country
    The engine is so dirty you can't tell how bad the hoses might be.
  8. Air_Boss
    4,140
    1,154
    New Yawk
    Likely, dealer can't either... but, hey, $1000 to look closer...
  9. tony_2018
    tony_2018 Member
    227
    66
    Depends, if you've never replaced them before be prepared for some dough leaving your bank. There are alot of hoses to replace.
