Hybrid safety plug
Discussion in 'Gen 5 Prius Main Forum' started by Ted Zalkind, Oct 6, 2024.
  1. Ted Zalkind
    Ted Zalkind Junior Member
    Penn Valley Ca
    2015 Prius v wagon
    I pulled out the orange hybrid safety plug while cleaning the fan and duct work. After installing the plug, including the lock procedure, I have the "triangle of death" alert. Is there any way to clear this code? I would prefer to not have the car towed to a shop. Thanks! Ted
  2. purplePriii
    purplePriii Active Member
    275
    119
    Is this for a Gen 5 or Gen 3 like your profile? If the latter, you're in the wrong sub and may get better advice in the appropriate one.
    51,023
    you can try disconnecting the 12v for a minute.
    did you slide the handle up as the final step?
    search
    #3 bisco, Oct 7, 2024
  4. ChapmanF
    17,186
    I don't know about gen 5 specifically, but earlier generations had a safety interlock that gives a P0A0D trouble code if the orange plug is not plugged in all the way. "All the way" includes sliding the handle lengthwise after clicking it down; that's what completes the interlock circuit.
    If you read the trouble code and it's P0A0D, that's a dead giveaway.
  5. Hammersmith
    Hammersmith Senior Member
    1,961
    1,966
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, that sounds like what happened when I forgot to fully lock the plug when I did the fan/duct cleaning to my gen3. Scared the crap out of me. Just watch a video or two on exactly how to fully lock it, then go back and double check your work.
