Hybrid Supra in the works?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by krazypriuslady, May 8, 2012.
  1. krazypriuslady
    232
    metro Wash DC
  2. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    So then why does he say "So it seems the timing is perfect to fold in a sports coupe with a Toyota badge in the U.S." I wonder.
    Supra would be interesting, but I hold no high hope given how as the article states this project has been cancelled a million times.
    I'm not sure about all this hybrid talk for it. That will add cost and or increase weight and or reduce performance probably. I just can't imagine many people buying a frivolous toy in this thing's price range really care about hybrid unless it truly adds to it as a driving experience.
  3. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    That other car is a scion.
    I'm sure they are playing with prototypes. The article had the thing priced higher than a porsche boxter. That seems an unlikely car to wear a toyota badge.
    Actually the porsche 918 is a perfect example that electric motors add to performance. The instant torque of the electric motors make a compelling case for a sports car. But if you are going there it likely needs a different hybrid set up than the RX. Mg1 and planetary gear could go in the rear, with a small mg2 built for low speed torque, and a large mg3 powering the front axis. Likely this would also need a fairly big lithium battery or a supercap to give bursts of power for 5 seconds or so. Porsche went with the big battery and added a plug. A efficient turbo 4 seems like a better fit for such a car than an atkinson V6 as it takes less space and weight and would likely be more efficient in highway cruising.
