Hybrid System disconnects after awhile
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by david10tco, Aug 26, 2017.
  1. david10tco
    david10tco New Member
    Sunnyvale
    I have a 2007 toyota prius on about 173k miles. While driving around the dashboard suddenly lighted up with the red triangle, vsc, check engine, and a light that looks something like ((!)).
    My OBD Scanner shows 2 error codes, U0100, lost communication with ECM/PCM A; and U0111, lost communication with battery energy control module A.
    I can start the car, and drive around with the battery and engine for a few minutes, before the car will lose the battery and rely solely on gas. But everytime I restart the car I can use the battery for a few more minutes. Note that when I lose the battery the battery is still holding a charge but it's just that the car no longer depletes/charges the battery while driving
    Is this something I may be able to diagnose myself? Thank you for your help
    #1 david10tco, Aug 26, 2017
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Check or have someone else check the 12 V battery before you do anything else.
    IF.....it is the original OEM one (10 years old) then don't even bother checking it; just get a new one......and charge it up good before installing.
    49,446
    maybe need a new hybrid battery.
    1) check your inverter reservoir for fluid movement with the car in ready. if there is no movement, replace the pump.
    2) if there is movement, get a mini vci and read the codes properly.
    Beachbummm likes this.
  4. David1235850
    David1235850 New Member
    Bakersfield
    I have the same problem I changed the 12v battery and the hybrid battery as well and the same 2 codes keep coming up "u0100, u0111' and giving me the the check engine light as well as the red triangle what do I do ?
  5. Figster10
    Figster10 Member
    207
    60
    Sacramento
    Did you figure things out after replacing hybrid battery and 12v battery?
