hybrid system malfunction. engine not kick in
Discussion in 'Gen 2 Prius Technical Discussion' started by hc167, Jul 20, 2008.
  1. hc167
    hc167 Member
    132
    US
    I have a problem with my 2005 prius with about 64000 miles on it. It has check engine light on today with the red triangle today. Because I only drive for short distance today (about 4 miles). So I ignore it and try to worry about it tomorrow. Then on my way back to home. Another light beside the check engine come on and the car run in full electrical mode (engine is not on at all). So I park on the side of the street and call someone to tow my car to the dealer. because today is sunday. I am not sure I can park my car in the dealership overnight. anyway. I stop the car and start again few time and hit the gas. but no luck. the engine is still not on. Then the fourth time I re-start the car. the light on the side of the check engine light is gone and the engine is kicking in again. Well. at least I can drive home today. anyone know what will cause this problem?
  2. prius729
    prius729 New Member
    120
    Hobbs, NM
    How much gas do you have in the car?
  3. hc167
    hc167 Member
    132
    US
    3 out of 10 bars. is that matter? do you mean low gas will make the check engine light come on?
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi hc...,,
    Could be lots of things. Two common ones are bad gas, and the throttle body mechanism is sticking and needs to be cleaned.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Not low, but no. Running out of gas will do it.
    Tom
  6. prius729
    prius729 New Member
    120
    Hobbs, NM
    no, but from the previous posts I read here on PC your problem seems similar to others running out of gas.
  7. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    HEY!!!!!!!!!!! wait a minute! i was always an avid poster about NOT running out of gas, but this thread is a bit concerning................THREE PIPS LEFT AND HC167 ran out of gas??????
    let me clarify my question/comment.................CAN YOU BE OUT OF GAS AT 3 PIPS?
    2 PIPS? IS THIS A POSSIBILITY?
  8. hc167
    hc167 Member
    132
    US
    I do not think the problem is out of gas. because the ICE can be kicked in again today and last night. anyway, it is at the dealership and I should know soon.
  9. hc167
    hc167 Member
    132
    US
    just back from dealership. they said there are about 9 codes plus 6 penging codes. two codes for battery, 1 for ABS. 1 for AC, ....... doesn't matter anymore. this is unusual. and the dealer said the same too. so what they do is they clear all the codes and do a 10 mins test drive. and the codes did not come back. they have no idea why. I just drove about 30 mins (30 miles too since I was driving 60mhp on highway) my car seem to be ok. is it a bug in prius computer system????? anyone??
  10. bwilson4web
    15,518
    We need the codes. An intermittent problem could cause a lot of codes and clearing them without recording them, leaves us blind to potential problems.
  11. hc167
    hc167 Member
    132
    US
    hi bwilson4web:
    I agree with what you said. but why is unrelated codes appeared at the same time? for example, why is there a keyless entry code there? anyway, I understand your point. but I believe if there is a problem, then the code will come up again. I will buy a scanner and do it myself. I generally do not 100% believe those dealer. especially when they hire those young guys to work on my car. And I do think that toyota is a good car with good hardware. I just don't trust on their software.
    anyway, maybe I should mention one more thing, that check engine light came on when I reset the service maintenance light without changing oil two days ago. I did that because my last oil change I used mobile 1 and the condition of the oil is still good. Please don't tell me that this will bring up the check engine light.
  12. Patrick Wong
    18,200
    6,472
    Without knowing what the DTC are, how can you assert they are unrelated? For example, a problem with the DC to DC converter could cause the voltage on the 12V bus to sag. This would cause DTC to be logged by various ECUs which might not appear to be directly related to each other.
    If the check engine light is coming on, then the engine ECU is logging DTC. However, without a list of the DTC, it is hard to say whether your problem is as simple as a loose gas cap, or an ignition misfire, or a bad catalytic converter, or failed variable intake valve timing, or a bad engine coolant heat recovery system, or ??
    Hence, it would be wise to ask your dealer tech to carefully record all retrieved DTC and enter them upon your service invoice, so that you have a record for future reference.
    You can buy an OBD-II code reader. I suggest that you ensure that it is compatible with the Toyota communications protocol. Even if compatible, it may or may not pick up the DTC logged by the various Prius ECUs.
  13. richard schumacher
    7,663
    1,038
    United States
    Or even as simple as the 12V battery being low. Is this the original 12V battery? Have you ever drained the 12V battery by leaving a door or the hatch open, or the lights on?
  14. hc167
    hc167 Member
    132
    US
    I have never drained the battery. but the dealership that I purchased did. This is the car that I purchased used last year. and when I tested drive the car, they actually needed to jump start the car. anyway, I will need a scanner with me. I do not really trust the dealer. Not that because they do not have the knowledge. but they never want to do a good job on my car (I should say anyone's car). and for a small problem. they keep telling you that this entire thing need to be replaced. I will ask my friend about my car check engine light issue. he can access alldata. So maybe I can find some information there. yes, you are all correct. they maybe related issue.
  15. hc167
    hc167 Member
    132
    US
    yes, it is the original battery
  16. hc167
    hc167 Member
    132
    US
    my check engine light is on again today and I sent it to dealer. They did a quick scan and only found one code this time. I did not ask them the code but they said it is the generator sensors. so they will need me to drop off the car for about one day.
  17. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    if you buy a scanner make sure it supports CAN protocol.
    if anything happens again it should be covered under warranty instead of being erased by the dealer, if you send it back ask for a printout of the diagnostic check.
