Hybrid System Warning Issue
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AbiDuf, Jan 11, 2023.
  1. AbiDuf
    AbiDuf New Member
    United Kingdom
    I have a 2014 Prius which is a japanese import (to the UK) and had 60k on the clock.
    Since september I have been having an issue with the 'Hybrid System Warning Light' coming on. The light comes on and the hybrid system shuts off. The mechanic I have been going to has told me that the battery is functioning at about 60-70%, so seems to have a lot of life left in it. When he attachs it to the computer it says that the hybrid battery needs replacing.
    He can reset the system and the car works fine for 4-5weeks before the error comes back up again. He has tried various things to fix it including:
    - Replacing the auxiliary battery
    - Cleaning the hybrid system including the cooling fan filter, colling fan and ducts
    - Taking out the battery and replacing/checking all the wires that link eveything together
    I am at the point where we are considering getting a new battery, however I am a bit loathe to do it as I think the car is quite young and doesnt have a high mileage, also it seems to be functioning well for quite long periods.
    Has anyone else had this issue? Could you give me some advice?
    Thanks, Abi
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,470
    6,564
    Texas Hill Country
    Unfortunately, batteries are often degraded by age as much as by miles. Sometimes allowing them to sit without operating for a long period of time is equally bad.
    Certainly an option is to open up your hv battery and clean the bus bars, and perhaps replace the worst modules. Which is exactly what the battery refurb people do with limited success.
    The best solution is to replace the group of cells with new.
  3. AbiDuf
    AbiDuf New Member
    United Kingdom
    Thanks for getting back to me!
    I think the previous owner must have not used it too much because it only had 30k on the clock when we got it in June 2019.
    The mechanic has said that the report he has produced doesn't show any degradation in any particular group of cells. He has got the car again today for a few last checks.
    From reading through some previous posts on here I can see that perhaps replacing the whole battery might be the best way to go. I'm now just worried the car might go into limp mode before the new battery arrives!
  4. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    I'd recommend getting the DrPrius app on your smartphone (if have one), and an inexpensive ODB2 bluetooth adapter - activate the DrPrius app, battery tests - and get your own report of the traction pack health.
    Hummm .....
    That's not a difficult job, if experienced. There are tricks to getting results that last longer than a few weeks.
    #4 vvillovv, Jan 12, 2023
  5. Mendel Leisk
    41,871
    I’d second Dr Prius app. Take screenshot and post here, the one that looks like this:
  6. ChapmanF
    18,512
    I'd rather see the actual code, but I'm assuming he means it was P0A80.
    The conditions the ECU has to see to set that code are kind of stringent, so it's entirely possible that you clear the code and are able to drive for some time before the ECU rediscovers there's a problem, and sets the code again. You can keep doing that until you can't ... sometimes the way you find out when you can't anymore is a bang and bad smells from the back of the car, and a tow.
  7. vvillovv
    4,324
    1,512
    NY
    Don't sugar coat it Chap.
    Seriously, Chap is correct, if your cars problem is actually the traction packs condition or lack there of.
    DrPrius will also show most of the traction pack related DTC (diagnostic trouble codes) so you might be able to see what code the car is throwing when you get them.
    #7 vvillovv, Jan 12, 2023
  8. AbiDuf
    AbiDuf New Member
    United Kingdom
    Thanks so much for all your responses, I've ordered a Veepeak OBD2 scanner as recommended by Dr Prius and I'll post a report here once I get it. The mechanic had another look at the car yesterday and has suggested that as the problem is so intermittent I should just clear the codes myself with the OBD2 scanner until the error comes up more frequently and then he can get the new battery ordered asap.
    I was concerned about the potential of a bang and bad smells but he said it shouldn't damage the car to keep the battery going for a while longer, so fingers crossed!
    vvillovv likes this.
