hybrid sytem stop immediately message low inverter coolant
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Maui G, Apr 20, 2019.
  1. Maui G
    Maui G New Member
    Maui
    After one stop today I started Prius c one 2013 and got the check hybrid system message. I searched the internet for info. I then clean some minor dust from fan vent - still got message. Read about inverter coolant and looked under hood and it was below the L maybe 1/2' or more. Maui Toyota was closed for good Friday and also has a bad reputation. Overpriced, takes days and hours to get appointment and repairs can be insanely expensive. Only dealer on island. Obviously no info from them.
    Made several calls and no one here wants to touch hybrid system or knows anything. I was able to finish work errand and drive home. Only gas engine seems to be powering the car.
    Can I just open the coolant lid and add some distilled water. Would that solve it?
    Can I drive the car like this until I can take to dealer?
    49,504
    you can probably drive slow, but don't add water. get some inverter coolant at the dealer, and start checking for leaks
  3. Mendel Leisk
    38,734
    I would make a dealership appointment and only drive it, gently, to get to that appointment (whenever that is, say next Tuesday, what with the long weekend).
    #3 Mendel Leisk, Apr 20, 2019
  4. ChapmanF
    15,662
    Distilled water temporarily probably won't hurt anything, but it will be a trick getting the coolant to the right dilution again afterward, because the Toyota SLLC is sold already premixed at the correct 50% dilution.
    In the ol' days coolant would be sold straight, and you could add about as much of it as the distilled water you put in, and end up back at 50%.
    jerrymildred and Mendel Leisk like this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Hmmm......let's see.....where he lives, the temperature goes below freezing.......how many days a year ??
    I think ZERO.
    Adding water should be fine.
  6. Mendel Leisk
    38,734
    Would 1/2" below low line in hybrid coolant reservoir trip a warning? I kinda doubt it, suspect the invert coolant pump failed, but who knows.
    dubit likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    That could be where it's leaking.
  8. ChapmanF
    15,662
    Water should be ok temporarily, as long as the right concentration of SLLC (which has a corrosion-protection purpose, not just an anti-freeze/anti-boil purpose) can be restored soon.
