hybrid transaxle oil replacement intervals
Discussion in 'Generation 1 Prius Discussion' started by statultra, Jul 4, 2008.
  1. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    how often do you change HV transaxle fluid, Type T-IV?
  2. bwilson4web
    15,513
    I have switched to Type WS and change it on an accelerated schedule to monitor wear materials. However, it looks like I can switch to a once every other year, about 30k mile, interval.
    The Type T-IV looks to need changing between 15-30k miles due to a loss of viscosity. There is a sticky with the transaxle oil study data.
  3. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Remember the Type T-IV should only be used in the 2001-2003 Prius. From 2004-on it's strictly Type WS.
    Wayne
  4. patsparks
    10,664
    567
    Adelaide South Australia
    The WS oil is under $50 at Toyota dealers. I did mine at 80,000km and will do another change at 160,000km, that is 50,000 mile intervals for no reason but I think I should.
  5. statultra
    796
    30
    Edison,NJ
    2001 Prius
    WS works on the 01-03 prius?
    i have used Type T-IV on one of my 01 priuses, any dangerous with going to WS? i have like 6 quarts of the WS in my garage so that would be great
  6. bwilson4web
    15,513
    It remains an experimental technique until I get another oil sample tested.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Well, I'm running the same "experiment" on my 2001 as of two months ago.
  8. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    130k with no ill effects.
