Hybrid Vehicle Dismantling Manual
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pakitt, Dec 31, 2009.
  1. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    Available here.
    Some interesting information in the first pages of the manual.
    7 people like this.
  2. Flying White Dutchman
    4,374
    313
    i am going to download it.. lets see what it is.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    This is an excellent document. It can be used to counter all sorts of FUD, it explains why we need a 12 volt battery in addition to the 201 volt battery, (very nice relay schematics) and it explains how to remove the HV battery, so can be used as a HV Battery replacement guide.
    Thanks!
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    It is interesting that the document does not identify/locate the brake
    system Power Source Backup Unit, a 12v capacitor array: :confused:
    It is located under the hatch area floor, next to the "regular" 12v battery.
    Although, "The electrical charge stored in the capacitor cells becomes
    discharged when the HV system tops operating after the power system
    is turned off,"
    the unit could still be hot when responders first arrive. :eek:
    http://www.autoshop101.com/forms/Hybrid16.pdf
  5. Flying White Dutchman
    4,374
    313
    thats only 12volts..
  6. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    I did not see an mention of the DC/DC converter that charges the 12v battery. Does anyone know where that is?
    Thanks,
    Dan
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    For sure.
    But one of the big concerns for first responders in any auto accident is
    circuitry which might result in sparking that could ignite fuel fumes.
    I don't know that it matters, but the Power Source Backup Unit is not
    that far from the fuel tank... which probably has a bladder... which
    might be difficult to puncture... etc, etc.
    OK, enough already.
    My point is the document doesn't even acknowledge the PSBU is there.
    It does address the 12v "regular" battery.
  8. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    This is only a manual for removal of the HV battery for disposal. It is not purpose for emergency work nor as a repair guide.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  10. Re-builder
    Re-builder priusrebuilder
    Ridgefield NJ
    Here's a link directly to that PDF
    also Here's a link for Free step by step instructions to remove your Prius Hybrid Battery
    Sincerely
    Mark
