Hybrids can and will kill you, according to Ford Hybrid Tech
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Feb 21, 2008.
  1. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I had to make the title as funny as the article is. Here's a Ford mechanic talking about how if you work on a hybrid and someone opens the car door while you are under the hood you can die:
    DENVER -- They are quiet. They save energy. But hybrids may also hold a hidden danger if they are involved in a serious accident.
    "The car was totaled," said former Prius owner, Rusty Wehner. "We got spun around 270 degrees."Wehner learned from a mechanic after the accident that totaled his Prius that there was a risk of electrocution.
    "You're thinking more about the environment and more about saving money than anything else," he said."If you don't know what you're doing you can be hurt seriously, if not killed by the voltage," said hybrid-certified mechanic Kevin Klein."There's 330 volts of electricity running through the lines," said Klein.
    ...."We have to cone off the area when we're working on the vehicle because just opening the door activates the system. So if you're under the hood working on it and somebody comes up and opens the door, you can be electrocuted," Klein said.
    Complete with video:
    Hybrids Hold Hidden Dangers - Denver News Story - KMGH Denver
    http://mfile.akamai.com/12930/wmv/vod.ibsys.com/2008/0221/15364876.200k.asx
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Yes, and what about that 10 or 20 gallons of gas in the tank? People are nuts.
    Tom
  3. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    I can imagine the same scenario if all vehicles had always been powered by high voltage, and then suddenly, gasoline was added as a new feul. Then the topic would be special training for first responders regarding precautions needed for those new fangled liquid petrol lines. The jaws of life could cut right through one of those and a spark would cause an explosion.
    Seems like one easy fix would be if the high voltage cut off could somehow be tied in with the air bags. Air bags deploy = high voltage killed. I think the cables are protected well enough to prevent them from being damaged or exposed in minor crashes that would not deploy the air bags.
    Did that Ford Escape hybrid in the news video have the orange high voltage cables exposed on the exterior of the frame under the car, or was I dreaming?
  4. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Isn't the power to the high-voltage cables off except when the Prius is in operation? In other words, copper thiefs could take them? (although if wrong, I would not mind the outcome. :D )
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    they only have to cone off the vehicle if the hv battery needs to be charged. geez. my husband safely worked on them for years. oh wait, he had special electrical shock resistant work boots, that must have been it.
  6. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Did he wear 4 pairs of gloves to be sure, too? :)
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    What nonsense!!
    With the Prius:
    First, unless the car is turned on the HV output is totally disconnected, both sides (+ and -).
    Second, if turned on, both sides (+ and -) are ground fault protected. If EITHER are connected to chassis both are disconnected -INSIDE- the battery box. You could draw a few mA for a fraction of a second from either, but due to the short duration, it's doubtful it would kill you. It WOULD certainly scare you! I've been hit with 600 VDC and it isn't fun! It results in burns and very sore muscles (because DC causes extreme muscular tightening).
    Unless, of course, this is another Ford "better idea", like the Pinto! Does the Ford junk have the ground fault system and the relay in the battery box?
  8. Tideland Prius
    16,142
    The car is activated when someone opens the door?? :moony:
    what the heck :confused::confused:.
    I guess their regular car's fuel line and engine also automatically start when they open the door too? I've never heard of that feature! :rolleyes:.
    Side note: Whoa... when did all these new smilies show up? There weren't there 5 mins ago lol :whip:
  9. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    330 volts RUNNING through those wires??? :rolleyes: VOLTAGE IS PRESSURE, IT DOES NOT FLOW! It's amps that flow, this guy is not an Einstien. I'm somehow glad this guy will never have to work on our car. And for the fire and rescue people, I'll somehow bet they are all trained on this, heck, the chief of our local fire/rescue dept even drives a HiHy, complete with fireman plates. :)
  10. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    tleonhar,
    Let us cut him some slack. He is a hybrid mechanic, probably doesn't have EE degree. He probably didn't like the physics class in high school either.
    He wouldn't understand that the static charge on his cloth could be as high as thousands of volts. Now that is much more scary than 330 volts.
  11. darelldd
    6,057
    389
    Northern CA
    Remember, this is 330 V of electricity as spelled out in the article. I guess because it is electricity, that makes it more dangerous.
    Such BS that I'm not gonna waste any more time even thinking about it.
  12. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Hey Guys,
    Most of us are aware of the Prius built-in automatic battery safety disconnect, but the news broadcast also was about the Ford Escape Hybrid. Remember its' a FORD - The same people who brought us the Pinto with the exploding fuel tank (if hit hard from the rear-end) and the Ford Explorer SUV (which had tire & handling problems). With Ford's established reputation, it is no wonder why the general public is a bit suspicious.
    Hey, Ford should market this feature - In case of a serious accident in one of their Escape Hybrids, you can can get out of it in one of two ways - regular or extra crispy!!!
    Keith :)
  13. adamKrain
    adamKrain New Member
    This idea of electrocution seems to run in parallel with wiring a house. Disconnect the source of electricity before you work on the vehicle. Usually you do with a normal gas engine machine as well.
  14. hill
    8,167
    Even so, it IS supposed to be a great SUV. Crossed licensed off the Toyota model, so Toyota wouldn't sue for pattent infringement. That said, I wonder if the Ford guy wears his face shield & gloves while topping off the water in a regular ICE car's battery (probbably not)
  15. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    this mechanic must be the stupidest mechanic ever,
    i love this part so badly
    if this were the case i would buy a excursion
  16. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I believe in wearing protection when I work on my Prius. I prefer Trojans.
  17. hill
    8,167
    For protection, our Prius is Sponge Worthy.
    :D
  18. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Did this guy get his certificate out of a Cracker Jack box or off the back of a cereal box?
  19. rogart1
    rogart1 Junior Member
    31
    Canada -NS
    Remember he is talking about FORD not Toyota. One has to wonder how well the Ford people are actually trained on Hybrid's ?
  20. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
    Alas, in TV journalism sensationalism attracts more viewers than facts. The first guy interviewed in the story obviously survived a collision that totaled his car, so that should be a good testament as to the crashworthiness of the Prius.
    It's a good thing Toyota Engineers thought of this, too. In the event of a collision (rapid deceleration) or airbag deployment, the contactors (big power relays) in the battery box disconnect it from the rest of the outside world. There is NO danger of electrocution unless the integrity of the traction battery box is compromised, which is highly unlikely since it's encased in a metal box in the middle of the car. The other point of stored energy would be the high voltage capacitors used in the inverter. Normally these are discharged within 5 minutes by bleed resistors. A frontal collision that breaches the inverter case could expose the HV caps, but the inverter is pretty well encased and this would also be highly unlikely. I personally would be far more worried about spilled gasoline from a collision.
    Quoting Gary Smith, the National Service Technology manager at Toyota Motor Sales, USA, Inc:
    Toyota: Toyota.com : Hybrid Synergy View : 2006 : Fall : Battery Q&A
    If you want to read more in the Toyota First Responder's guide, follow this link:
    https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti;TISESSIONID=HMS521bLjylQpVL190pg92D7GYj02VGtFwJTLLXy8hjqvkPxQwdF!814507913?_pageLabel=ti_erg&_nfpb=true
    Since Ford licensed the hybrid technology from Toyota for use in the Escape, I'd guess the Escape uses a similar electrical system to what is found in the HiHy. Technician training is another matter.
