Hydraulic Hybrid Hype
Discussion in 'Gen 2 Prius Main Forum' started by jeneric, Dec 6, 2005.
  1. jeneric
    jeneric New Member
    442
    Redmond, WA
    Here's the Wired post.
    Kinda interesting, I always liked the flywheel idea, but the weight and speed of the flywheel seems like it'd be a problem. A pneumatic solution is cool, I wonder what kind of condensation and other heat issues you'd get. The inefficiency of converting mechanical to electrical energy will always bother me until we get some nice superconductors going, but I'll be all right.
  2. daronspicher
    daronspicher Active Member
    1,208
    Ford did something like that to a concept car version of the F250 a couple years ago. If I recall, they were compressing some kind of fluid upon braking, and releasing it at acceleration. They were getting 35mpg with a F250 superduty.
    I'm not sure why this isn't coming to market yet. I imagine there are some safety considerations givin the pressures on tubes and storage devices with this. You get that thing fully compressed and then crash real hard. That couldn't be good.
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Someone please correct me (and I know you will :D thanks) would not a big high mass spinning flywheel act like a gyroscope and tend to resist changes of direction.
  4. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I would think so... too much turning would kill the efficiency of the flywheel.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think we are talking forward momentum and emergency stops. the brakes would have all that much more kinetic energy to stop with a flywheel like that
  6. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Yes, it was the Ford Tonka Concept. IT was the prototype for the new Superduty. It was similar to the Prius's regenerative braking system, but it captured the braking force as mechanical energy rather than electrical. As with the Prius, it was most beneficial in stop and go traffic. Made a huge difference in mileage. Here it is. If they had actually made this, I'd be driving this rathe than the Prius.
    Here is a tech blurb about the Hydraulic Launch Assist:
    "Ford has also cooperated with automotive supplier Eaton Corporation to introduce Hydraulic Launch Assist (HLA) into the Mighty F-350 Tonka's powertrain. A brand new concept designed to greatly improve fuel economy, HLA recovers some of the energy lost during braking and converts and stores it as hydraulic pressure. During acceleration this stored energy is released and its torque applied to the driveshaft through the clutch. For 10-15 seconds all acceleration comes from the HLA system while the engine idles."
  7. jeneric
    jeneric New Member
    442
    Redmond, WA
    I think the only direction change it would resist is falling over. Like a top, they're happy to move sideways, aka turn. Of course, I dropped my Physics major.
  8. windstrings
    6,280
    378
    Central Texas
    Yea.. I don't know much about it.. whether its mounted vertical or horizontal.... I was thinking vertical.... sounds like your thinking more like a top.. horizontal?.. I don't know.
    Would probrably make for a very stable ride going down the road, but if mounted horizontal "like a top", even bouncing down the road would tend to stablize to make a nice ride, but the kinetic energy absorbed by the centrifugal force may kill the efficiency of the gyro.
    All this is pure speculation... would be fun to test,....
  9. DocVijay
    1,455
    Tampa, FL
    Picture above fixed. That's one cool truck!
  10. Tigerops
    Tigerops New Member
    84
    Or maybe they would make two opposing systems to cancel out the gyro effect on the ride??
  11. windstrings
    6,280
    378
    Central Texas
    yea.. they would fight against each other and both would lose.. kinda like fighting against your wife!! :lol: :lol:
  12. benighted
    benighted New Member
    530
    Westport, WA
    If it was mounted vertically it would be just like having another wheel spinning. I think that would make the most sense
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    force of the wheel would be perpendic to the direction of rotation. if rotate is parallel to front of car as opposed to parallel to length of car, force will be straight out or pointing towards front.
    like a top that seems to never fall, the reason is the force exerted is up because direction of spin is parallel to the surface its on keeping the top upright
  14. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    OK my dyslexia did me in I did not consider orienting in the other direction because I was visualizing a more simple linkage like the fly wheel on a car or the clutch. Very interesting.
  15. SteveT
    SteveT Junior Member
    30
    Illinois
    I know there have been test vehicles using flywheel energy storage systems. The ones I recal were city busses in the late 90's in Europe. The flywheel power packs used two flywheels rotating in opposite directions. The disadvantages of flywheels is the same as many other alternative energy sources... size, weight and expense. The flywheel packs were heavy and used a lot of energy just to keep everything working.
    To keep the mass down, the flywheels rotated at 100,000 RPM. It required a very strong "blast shield" around it to contain any shrapnel in the event of failure. They had to be held in a vacumn and use magnetic (non-contact) bearing or the enrgy loss was too great. Obviously, this used a lot of energy to maintain and was expensive and bulky.
    The outer rim of the flywheel was the rotor of a motor-generator and the stator was in the housing around it. That was how the energy was put in and taken out.
    There are flywheel storage systems out there for UPS applications. Perhaps in time, some of the difficulties will be worked out and volumes will get to where it is cost effective for mobile applications.
    Steve T
  16. Kiloran
    Kiloran New Member
    1,225
    It would be different because the wheel would be much more massive and spinning with high energy (as that's its purpose).
    The only arrangement that makes sense for a vehicle moving and rotating in 2 dimensions (simplified description of what a car does) is for the flywheel to spin around an axis purpendicular to the plane formed by those dimesions (like a top).
    This arrangement will not interfere with direction or rotation changes within that plane (moving and turning) but will resist direction changes that cause the axis of rotation to change (flipping and sudden changes in attitude, ie. rapid banking or encountering sudden steep hill).
    (This was my best mechanical engineering course.)
  17. windstrings
    6,280
    378
    Central Texas
    Quote from Mr. Spock
