Hydrogen Generator
Discussion in 'Gen 2 Prius Technical Discussion' started by LoveToSail, Aug 13, 2008.
  1. LoveToSail
    LoveToSail New Member
    Has anyone had any experience with Hydrogen Generators? :confused:
    It basically injects HHO Gas into the Intake Manifold (behind the Air Filter).
    I am thinking of putting one in my Prius to see if I can get a significant increase in Gas Mileage.
    Experiences or thoughts anyone?
  2. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    Takes energy to make the hydrogen - that has to come from somewhere. Electrolysis gives off heat, so it's not reversible. TANSTAAFL.
  3. LoveToSail
    I'm trying to keep the Amperage to a minimum.......which in turn will keep the Heat down to a minimum.
  4. Devil's Advocate
    922
    Las Vegas, Nevada
    The key to H2 is not "efficiency" its Energy independence and Cleanliness.
    Of course the process needs some improvement and the electricity would have to come from "green" sources, but H2 is an energy storage medium and until (if ever) battery or other energy storage is sufficiently developed we will need a replacement for fossil fuels. (Let's see a jet fly on battery power! Well, it wouldn't be a jet but something with the same performance.)
  5. pdhenry
    406
    PA
    I think the OP is talking about electrolyzing water onboard his car, so it is about efficiency.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's snake oil, in it's pure and simple form. The only gain from these hydrogen generators is to the bank account of the people that sell the plans and kits. What you gain from burning the hydrogen is more than offset by the energy cost of liberating it. Skip the hydrogen generator and try something better proven, like putting a Plastic Jesus on your dash.
    Tom
  7. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Two thoughts.
    1) HHO is water, not hydrogen gas. Water doesn't burn, and I doubt injecting water into the intake is going to gain you much benefit.
    2) If you decide to inject HH (Hydrogen gas), I'm curious as to where you will get the hydrogen. You could purchase it, I'm not sure how much it would cost nor whether you'd improve your miles per dollar that way. You could generate it at home off the electrical service to your house, depending on your electrical costs this might have a slight cost per mile benefit. You could generate it from the vehicle's electrical system, while you may have individual trips or tanks that appear to have an improvement, since the vehicle gets it's electricity from burning gasoline, this is likely to cost you more in the long run.
  8. LoveToSail
    Electrolysis generates two parts Hydrogen Gas to one part Oxygen Gas (HHO Gas).
    It uses the existing 12-volt system at a modest amperage. The Gas Generator along with the Electronic part that interacts with the oxygen Sensor is supposed to give a pretty good boost to the MPG's along with cleaning the engine and emitting some water vapor hence the "Green" benefit..........still uses gasoline, but less of it.
    By the way, the plans are free on the internet and can be built from Hardware store parts...........~$150-200.
    I've been averaging 44 MPG and hope to get at least 60+ with this modification.
    I was wondering if anyone had already done this.......:cool:
  9. ChapmanF
    15,430
    The key to any kind of proposition like this one is whether the person advertising it can throw in enough plausible-sounding claims to successfully distract you from the fundamentals.
    Chief among the fundamentals is: you don't get any energy that didn't come from somewhere. So you need to be asking the question: what energy am I getting, and where did it come from? This one simple question can be very useful in defending your money from people who wouldn't mind having it.
    In this case, the energy you're getting is the energy released when you combine HH with O in the combustion chamber, forming water. Good, that releases energy. How much? Not one joule more than you put in by electrolysis to split the water into HH and O to begin with. Where did that energy come from? From the battery/electrical system, ultimately put there by the gasoline engine, which got it by burning gasoline.
    It's not clear what you're thinking of as "modest" amperage, but let's put an upper limit on it. You're not going to exceed 100 amps without blowing your Prius's DC/DC converter fuse, so you have an outside maximum budget of 1200 watts to put into electrolysis (12 V x 100 A). That gives you directly an outside maximum of 1200 watts to recover by recombining the HH and O when you burn it. Given that your gas engine is rated around 56,000 watts at full output ... 1200 watts is not likely to make anything like a 40-50% difference in your overall performance - even if you do forget for a moment that those 1200 are coming out of the 56,000 available from the engine to begin with.
    You might want to do a little googling around whatever firm is advertising the kit that you are looking at. A relative of mine asked me to look at one such outfit (not necessarily the same one you've found) that turned out to have a name I recognized as its Director of Marketing. This gent formerly had a business called something like Better World, whose shtick was to sell you an electric motor/generator you could put in your basement. The motor would turn the generator using electricity produced by the generator, and you would use the extra to power your house and sell back to the utility. Just about exactly the same proposition, really.
    He has also visited a couple of years with the California dept. of corrections. All his publicity says it was over an "obscure civil code violation" and proved that somebody wanted to suppress his breakthrough technology. It was actually under a deceptive marketing provision of the state's consumer protection laws, unsurprisingly enough. As I said, the outfit you're looking at might not be exactly the same one, but you might learn some entertaining things about it just the same.
    If you achieve such a result, please do report back with the details.
    Good luck,
    -Chap
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    I have to second this. Please capture data both before and after installing the device.
    Also, if this really works, forget installing it on your car - use it to produce energy with a generator and sell that energy back to the power company - you will be rich.
  11. dogfriend
    7,512
    1,185
    Carmichael, CA
    We did put a plastic Jesus on the dashboard of the GF's motorhome. We can't tell if it helps the FE because we can't afford to fill up the tank to get a baseline. I think it does help though.
  12. qbee42
    18,058
    3,074
    Northern Michigan
    Fill the tank with water. If you have a really good plastic Jesus he will turn it into gas.
    Tom
  13. dogfriend
    7,512
    1,185
    Carmichael, CA
    :pray2: :rofl:
  14. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    Hell, I say go for it! (sorry plastic Jesus) It is, after all, your money and time. I have seen a few threads on here pertaining to this subject, but no one has pursued it. Post your results and give us the definitive answer to the snake oil question. You will be a hero either way! I bet 15-20 years ago the idea of running a car on batteries and gas in some funky union of technology would be considered science-fiction, or even snake oil.
  15. szabi
    szabi I also have a 2007 Prius
    25
    200 mi N of SF Bay area
    Speaking as a physicist with grad work at Stanford who has worked in Silicon Valley for 25 years, I can assure you that all these "save fuel with hydrogen generator" schemes are 100% triple-distilled Bull Manure. I will not bore you with technical detail because anyone that can actually follow such a discussion as a rational discourse rather than throwing long words around would never even raise this question.
    "There's a fool born every minute" ..Phineas T. Barnum
  16. qbee42
    18,058
    3,074
    Northern Michigan
    Some things are so easy to disprove that there is no utility in wasting time and money to test. This is one of them.
    Tom
  17. LoveToSail
    We are using Gas and generating 12 volts already. What I am talking about is getting more miles out of a gallon of gasoline.
    I am talking about roughly 10 amps or less. The amperage depends on the cell area (square inches), efficiency of the cell configuration and electrolyte saturation. I am looking at one called the SMACK'S CELL.
    I am wary of these scams. I have researched this and it appears to be legitimate. Putting this particular idea to work in a Prius is why I asked my original question. As we know, the electrical system in a Prius is a little different. I saw mention of someone having tried this in a Prius successfully, but gave no lead on who or how to contact that individual on how they wired their Oxygen Sensor into the system. I was hoping that someone here had done so, or at the very least knew of someone that had. I don't want to even attempt it until I feel comfortable about this particular step.
    I will certainly report my results back to you when I do get this going. I know this would be of great interest to a majority here.........;)
  18. pdhenry
    406
    PA
    I think "HHO Gas" may be tricky semantics to make the buyer think they're injecting a mix of hydrogen and oxygen, but it's probably referring to water vapor (which is more properly HOH gas).
  19. pdhenry
    406
    PA
    Ever take any thermodynamics courses?
  20. rep308
    rep308 Junior Member
    71
    suburbs of Boston
    I put a windmill on the roof of my Prius to charge the battery while I drive. If the battery level gets low I just drive faster to spin the windmill to charge it up.
    I have taken way to many thermodynamics classes.....
