Hydrolock?
Discussion in 'Gen 3 Prius Main Forum' started by mwok86, Sep 30, 2010.
  1. mwok86
    mwok86 New Member
    203
    16
    usa
    It was pouring down heavily this morning and most of the streets were flooded (I'd say about 1/4 feet), I was traveling at about 30mph so a lot of water was splashing on the sides.
    Is there any water damage (or rust damage)? (I don't know what hydrolock is actually)
  2. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Hydrolock is when the air intake for the Gas engine fills with water and the engine will stall when the water gets into it. It can be very costly to repair.
  3. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    3" of water shouldn't be a problem.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    On the way home from work this week I had to pass through roughly 12" of water due to flooding across the highway. I did not have a problem with this, other than being a little worried until I finally made it through.
  5. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    When I've driven through 5-7 inches of water, the only issue I had is the Under Bumper plastic deflectors being pulled back, causing them to scrape the road, my tire, and eventually get ripped off the front of the car.
  6. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    i'd take it really easy through water in the prius. i'm a little afraid of getting water into the electrical components.
  7. Joe166
    Joe166 New Member
    720
    96
    South Florida
    People that speed through standing water and make a wake are morons! They usually are driving plain, white pickup trucks with no accessories or options. Those are the people who need to get hydrolock. Or even hydrophobia!
  8. Superdrol
    Superdrol Member
    399
    32
    The car will typically come to a dead halt in a 'true hydrolock.' Your car sucks in air through the air filter and input into the engine in combination for combustion inside the engine.
    When it sucks in water instead of air obviously water is not combustible so the water floods the engine cylinders and comes to a halt.
    I posted a post about this and it is very funny when it happens to someone assuming it is not you.
    A true hydrolock will stop your car completely, sometimes you can get 'a little' water in and still be fine, but completely submerging the car and you are going to have a very expensive problem.
  9. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    I am finding it increasingly hard to believe that mwok86 is not a troll.
    Look at his other posts, including two about whether he's causing damage to his car flooring it (yes, he really asked--and twice), and another whether using the brakes in an emergency maneuver will damage them. Now he's asking if driving it in the rain is bad for it.
  10. Superdrol
    Superdrol Member
    399
    32
    And the answer is a unanimous yes. If you drive the Prius in the rain your penis will shrink and go inside out (not good).
  11. Barefoot
    Barefoot Junior Member
    43
    Lusby MD
    More importantly, water is not compressible.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    That's okay. The cylinder heads or connecting rods will make up the difference.
    Tom
  13. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Haha, yes, I was in a car that ended up with two nicely curved con rods.....
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    lol. good one tom
    i've been through heavy flooding. i was speeding through it too.
    after the puddle the engine stalled and my battery SOC started to drop... i pulled over immediately and turned the car off. i power cycled it about 20 or so times before the ICE would turn on (just enough to hear/feel the initial turning and firing of the ICE) it immediately went to full rpm for the ICE and the SOC started to climb slowly...
    i'm not sure if water was in the ICE or if the ignition coils simply got soaked.
    this was over 50k miles ago.
  15. Skoorbmax
    2,641
    264
    Western NY
    Was Superdrol right, then...?
    I have always carried a tarp in my prius and when it starts to rain I just stop on the side of the road and quickly cover it all up and bungee the tarp to itself snaking the bungee under the car. Sometimes I'll stand out for hours in the rain but I'm ok with this because I know the Prius isn't getting wet.
  16. Beauregard
    Beauregard Member
    89
    25
    Colorado
    2015 Prius c
    Hydrolock occurs when water is introduced into the combustion chamber of the ICE usually through the air intake. Water, of course, does not compress like the fuel/air mixture, and damage occurs rapidly. Valve trains, connecting rods and crankshafts bend and break under the tremendous mechanical pressures of the rotating mass of the engine. Usually the rear cylinders go first.
    Hydrolock almost always occurs from driving through deep water. If you're building a wave in front of the vehicle as you move forward you're probably in deep enough water to suck some into the air intake. It' doesn't take as much water as you'd think to cause a lot of expensive damage. It just doesn't make sense to me to drive through water more than about 3" deep, and it's very hard to estimate water depth from the drivers seat.
    The good news is most hydrolock damage is covered under the comprehensive road hazard insurance.
    Bo
