hydroplaning....tires or weather?
Discussion in 'Gen 2 Prius Main Forum' started by wrothgar, Dec 14, 2015.
  1. wrothgar
    wrothgar Junior Member
    oakville, ontario
    We have had a warm start to the winter here in Ontario. I have had 2 instances of hydroplaning while cornering, not sure if it's the driver's fault, weather, or tires:
    2008 pris with 15 inch Nokia winter tires. (I forget the name....'q' something...they are from 2003, but only have about 25000 km on them and seem to have great tread left. They were stored on rims for a few years and not used. Inflated to 33 lbs. They were great on ice last winter. This is my second winter with them. Last winter was cold....nearly always below 0 C).
    The first hydroplaning incidence was my fault: too fast (but only about 30 km/h) into a corner...small amount of rain. Wouldn't have happened with my summer tires though.
    Second incidence was in similar weather but my wife was driving and slipped on an on ramp. I'm not sure of the speed.
    So a few questions:
    1) do old winter tires lose grip on water but maintain it on ice? They really were good last year.
    2) Is 33 lbs under inflated? Weather has been so warm it's hard to get inflation right.
    3) how easy do people find it to spin their prius? I wonder about the weight of the battery in the back.....except I have never spunout in the summer.
  2. Mendel Leisk
    40,580
    Those are really old tires. Somewhere in the Owner's Manual you'll more-n-likely find a caution that a mechanic should check over any tires older than 5 years. FWIW, our's are coming up on 6 years, and I'm getting a bit nervous.
    If you're tires were closer to the 5 year mark I'd say look them over very carefully, especially checking for cracks. But 12 year old plus? Just get new.
    There's a number on the sidewall that'll tell you the year and week of the year that the tires were made:
    Tire Tech Information - Determining the Age of a Tire
    51,148
    hard to determine from way over here.:) it's never the weather, but how you adjust to it. i would recommend new tyres and slower driving.(y)
  4. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Winter tyres perhaps surprisingly are not so good in wet conditions as some summer tyres. They are however much better on ice, and snow. Also winter tyres are considered worn out with a much greater tread depth left than summer tyres.
    As "Mendel" above suggests your tyres are very old and as such are more liable to blowouts because of the degradation of both the rubber compound and the tyre casing. Check them very carefully for cracking on the sidewalls especially close to the wheel rims and the area where the tread starts.
    Tyre compounds have also come a long way in the last 10 years.
    John
    Data Daedalus likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    As noted above, those are old tires.
    It's up to the person.
    But here's my opinion, take it or leave it.
    If you are experiencing an increased amount of incidents where you are losing traction and spinning out in situations where you did not before? Then I think that's your tires trying to tell you something.
    It's a safety issue. So my bottom line with tires is if at any point I start to feel any set is making me insecure driving in common conditions, then it's time to get a new set.
    Really what's the worst case scenario? You replace tires over a decade old....that still "look" good? VS. Perhaps you save your life because your new tires have superior grip and traction.
    I don't think I'd put 12+ year old tires on my vehicle even if they looked factory fresh. All compounds degrade with time. Time is an agent of deterioration.
    I'd invest into good replacements, designed to handle the conditions you are most often driving in for that given set of tires.
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    I try never to skimp on tyres, for when it comes down to it, your tyres are the most important link between you and the road, so compromise at your own risk! :eek:
  7. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Sounds like the rubber has hardened over time. I would replace them...
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    953
    533
    Cow-lee-fornia
    2023 Prius
    Barring a worn out tread, my money is on the underinflated tires. Pump them up to 40f/38r and you should be fine.
  9. Mendel Leisk
    40,580
    Twelve year old tires, they may blow, lol.
  10. wrothgar
    oakville, ontario
    Well, I'm going to look around for new ones.
    Any suggestions? 185 65 r15 86s.
    Is hydroplaning common with new winter tires?
  11. Air_Boss
    Air_Boss Senior Member
    4,140
    1,154
    New Yawk
    Tires, tire pressure, and driving...
  12. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Even the newest and best tire will not prevent hydroplaning
    Tires are the only thing that keeps you vehicle connected to the road !regular maintenance , inspections, replace within 5 years even with good amount of tread on it , your life may depend on them. and slow down in foul weather!
    WilDavis likes this.
  13. wrothgar
    oakville, ontario
    I agree....but "foul" can sometimes be "fair". It seems to me that roads around here have been slickest lately when it only rains a tiny bit; and when there isn't even any ice.
  14. Air_Boss
    4,140
    1,154
    New Yawk
    First bit of moisture causes road surface oils to rise.
    That's the slipperiest non-ice/snow condition, which then just becomes a wet road when the road oils are washed off by heavier rain.
