Hymotion 2008 Prius 14 blink battery warning? How to proceed?
Discussion in 'Gen 2 Prius Technical Discussion' started by seatown7, Jan 31, 2012.
  1. seatown7
    seatown7 Northwest Prius Dork
    Seattle, WA
    2013 Prius Plug-in
    I'm getting the 14 blink code on my Hymotion LED indicating that my 12v battery is needing replacement. My question is that the car seems to run fine with the exception of my mileage is low. I'm ordering the Optima replacement. Can I still drive around for another week without worry?
    Thanks!
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I've always used http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html but just flipped between off and parking lights. No need to turn the headlights on/off and place unnecessary wear on HIDs (if equipped). I would only do either 12 volt test after the car has sat many hours/overnight.
    Your mileage will drop due to the colder weather and the illusion at high baseline mileage figures (http://priuschat.com/forums/gen-iii...mileage-gets-worse-in-winter.html#post1411488).
