Hymotion and Regen -
Discussion in 'Prius PHEV Plug-In Modifications' started by zcat3, Mar 23, 2009.
  1. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    Has anyone else noticed that even when the Hymotion system is enabled, the MFD will show some regen? I usually see a few half cars here and there. Is there really some regen happening or is it just the MFD thinking there is? I can usually get 6-8 fulls cars during my commute by turning the Hymotion off on the few long downhills - I figure that is worth a mile or two in EV mode.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The Hymotion battery does recharge the stock battery if needed and as long as there is enough charge in the Hymotion battery. But I don't recall seeing the regen for this process. I'll keep my eye on it to see if I see the same thing.
  3. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Yes, Regen is occuring while braking even when the Hymotion system is in operation. As a matter of fact, it is something of a concern to some of the Toyota Tech Experts (who shall remain anonymous) with whom I have spoken. The concern is possible overcharging of the original Prius Hybrid battery. So far, I have no other information on this particular subject.
  4. Arthur
    Arthur Member
    94
    55
    Corning, NY
    Regen with a Hymotion system operates the same way it does in a regular Prius, with all of the same limits in place. For all intents and purposes, a Hymotion Prius thinks that it IS a regular Prius. So, there is absolutely no reason to be worried about overcharging. (If you know something that I don't about possible causes of overcharging, please let me know.)
    The only difference is that, when the Prius traction battery goes down to a certain level, the Hymotion system starts sneaking little batches of energy into it (when it's not looking).
    So, a Hymotion Prius will do slightly LESS regen. That's because the Hymotion system will not let the traction battery go below a certain level. By design, that level is slightly higher than the level at which the ICE will kick on.
