Hymotion/Other Phev Mods - Who's taken the plunge?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by SVPriusFan, May 16, 2008.
  1. SVPriusFan
    SVPriusFan Hymotioned and loving it...
    115
    Denver Suburbs
    Greetings!
    I wanted to start a thread for and about those who have taken the plunge to convert their Prius into a PHEV (Those who have put down the deposit for a Hymotion BREM, and especially anyone who has already had this mod done by another company if there are any out there) - Please tell us about your experience!
    There's been plenty of threads that have already discussed aftermarket PHEV mod developement, and also the pros and cons of cost/range/payback period. I prefer rather to have this thread be about information on the conversion process and our excitement about having a great car that will be able to get 100+ MPG. Once I have the mod completed I'll definitely talk about my experience and also post some pictures.
    My current stats: Just bought a Magnetic Grey '08 #4 on April 30th (my second Prius!). I put down my deposit for the Hymotion BREM at the beginning of May, #97 on the list. I'll be having the mod done in San Francisco, which will allow me to take a vacation to see my family and friends. At present I don't have a firm appointment date but hope to have it done sometime in the July/August timeframe (according to Hymotion's email). Additionally, I'm not planning on any new graphics - I want the car to look totally stock from the outside. I'm also curious to know if the plug can be hidden next to the rear hatch handle rather than the ugly plug in the bumper that I've seen in other threads. Anyone have info?
    I certainly don't mind being an early adopter - I obviously think its worth it and am very excited:bounce: --- WHOHOO!!
  2. rwyckoff
    rwyckoff Phev's Plus Home Solar power1
    82
    Green Valley AZ.
    I put in my deposit 2 days ago, reservation#318 I think, and they are already out to Nov. installs. People are buying at least.
    I am guessing that they are using their power tool cell, m1. I count 88 cells in series for 290V nominal voltage (3.3v/cell). This cell would be great as a hybrid battery, low internal resistance, high power, but only medium energy storage. Not so great for phev's, and not as good as their new flat, square cell they are developing for GM and their Volt. But at least the M1 cell is mature, made in the millions, well tested, and somewhat cheaper.
    I have been using and testing these cells since they could be bought. They are good, have only killed one cell, after quite a bit of abuse. The company is experiencing a small amount of infant death of individual cells (three cases that I have run across).
    The thing to remember before you buy is that once the battery is run down to 40% of charge it is isolated from the system. That means you can not charge it with the cars hybrid system, unlike edrive's system. That is unfortunate because people in hilly area's could get better mileage with a larger battery backup. The advantage of HYmotions battery pack will be the life of the pack. It will last a long time because the pack will never have to give out more than 22kw for a few seconds, when it could put out as much as 120kw (30c), and the charge system installed with the battery pack is only 6amps which is only about .8amp (.4c) charge per series cell group. This will ensure maximum life for the pack, but the 4.5 hour charge rate won't help people who get home and try to recharge the pack for another errand later in the day.
    There will be other problems for people who want to do vehicle to grid hookjups or even direct DC voltage charging with solar installations or home assist arrangements.
    But maybe Ive given too much info already in the wrong forum, sorry.
    But with a PHEV and a solar power installation, I definately feel like I am finally living my dream. Thanks-
    Ron
  3. boxer93
    boxer93 Psyched for PHEV
    155
    22
    Southern NH
    Interesting SVPriusFan, My confirmation code is #97 as well. My initial deposit didn't process and I had to do it a second time.(Maybe we both hit the deposit button at the same time :D) I was told that I still had a July spot (in Boston). Unlike you I plan to do the graphics and tell/show as many people as I can. PHEV seem to be in a few fleets in the Northeast, but noting that the public can see. I want them to see.
    Hope to have some pictures in July.
    I'm actually installing the EV costal switch this afternoon in my brother in law's 06. Am considering this for the PHEV.
    Chris
  4. SVPriusFan
    115
    Denver Suburbs
    Ron,
    Thanks for the information. I'd be curious to know just what cells are in the L5 pack (the M1's you mentioned or something else). Have you experimented with an EV application using the M1 cells?
    Also regarding the L5 - are you saying it will be able to accept a charge from the Prius regen system as long as it is above 40%? - that would be a good thing to know. I'm assuming the 40% level means the pack has been completely used up as far as powering the car in PHEV mode...
    Chris,
    Two #97's -- I can only assume that means you are #97 for Boston while I am the same for San Fran? I'm also curious to know if the EV mode switch you are installing might be redundant once the L5 pack is installed. I had it in my first Prius but am not adding it to my new one since I signed up for Hymotion's package.
    Congrats to you both!:clap2:
  5. SVPriusFan
    115
    Denver Suburbs
    Chris - I just spoke to Erin at A123systems. The #97 is an error code relating to a problem they had processing our deposit (the problem was with their webpage and it affected several people). As you have had to do, she said that we have to resend our card info, I've just done this. But apparently my install date is in October :(
    She also said the Hymotion module will not accept a regen charge from the Prius's normal system - once the L5 is depleted up it can only be recharged from the bumper plug...
  6. Zythryn
    Zythryn Senior Member
    6,232
    4,228
    I also got #97 and was told I needed to resubmit. Currently my module is due to be shipped to my installer (Minneapolis) in August:)
  7. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    I'm #65 scheduled for Washington, but I told Erin I'd go to Boston if necessary. I was told mid October for installation. I put my deposit down on 5/7/08.
  8. boxer93
    155
    22
    Southern NH
    I doubled checked my reply from Erin and I am scheduled for July. I entered my deposit on April 26th. I wonder what position in the queue I really am. I was hoping the response was good enough to have 97 on April 26.
    Chris
  9. iLLa Prius
    iLLa Prius New Member
    42
    Lewisville, TX
    How Much Are You Paying For Your Kits? What All Do You Get?
  10. Zythryn
    6,232
    4,228
  11. iLLa Prius
    42
    Lewisville, TX
    i def wouldnt drop 10k. i mean i can build an upgradeable ev for that. if it made it a phev to where i could drive, say 60 miles just in ev mode, then i would give it a strong consideration. 10k is still steep. its a long time for payoff, plus i dont own a prius yet. so thats like 10k plus the price of a prius on top of it. i might be looking at 25k and up total. im pretty sure i can build my own custom phev for that. there are lots of options for the money, even a pneumatic motor.
  12. ldxcrunr
    ldxcrunr New Member
    25
    Long Island ny
    10 k i drive alot of miles a year on average about 32000. that would take ten years at 4.15 a gallon but gas is going up so maybe less time:confused:
  13. Zythryn
    6,232
    4,228
    That is completely your choice iLLa.
    Personally I am all thumbs when it comes to building my own paper air plane, much less a PHEV.
    I also look at it as quite a deal. My last car was a Lexus IS250 (35k). The Prius is basically the same car without the heated seats and with another 25mpg. With the module, it will be comparable in cost and get almost 4 times the gas mileage. For me it is a win:)
  14. iLLa Prius
    42
    Lewisville, TX
    i feel you. i see how you would look at it like that. i have an is300, my friend who is a dealer was like trade me your IS and buy this new IS350 off me, its loaded. I don't want a 18-20k loan on another gas guzzler. id rather drop 20k on a prius. even more so, id rather build my own prius. i really hate car payments, to me having one is almost like living above my means or having a car i cant afford. i might not be the most mechnically inclined person out there, but i know people what build cars from the ground up. my dealer friend is a sick mechanic. i know a lot about electronics. there are numerous books and forums to buiild your own phev. for a person like me, i have the resources and options. i mean if, you want heated seats, you can find some and install them. technology is getting better and cheaper for EV's. its worth me driving a 1200 corolla to save on gas, before dropping 20k into prius, just so that i can get what i want. hub motors are getting more powerful everyday. an easy hybrid to make when they get a lil more powerful, would to be take a front wheel drive car, put hub motors on the rear. you could drive with the gas to charge the motor batteries, assuming that the hub motors are also generators, as well as using high output alternators. i can find whatever used car i want and convert it. im just really picky about what i choose to spend time and money on, so sometimes its worth waiting. you are correct though, spending 35-45k on a new prius with the module is def worth it and it is very easy, its just not for me at this point.
  15. Cheap!
    Cheap! New Member
    1,157
    Well I've been driving one for over a year now. It is a lead Acid conversion. 100mpg is very possible or even more, but go just a few miles more than your range and see your mileage plummet. They do work great, but every now an then I have to go further then the range to do something. If I could afford it I would get a 60 mile range on mine, but even then, the Prius is not the best PHEV, it is only the best PHEV we have now.
    Doing this type of conversion for saving money is not the right reason. I did mine to reduce air pollution, and to use less foreign oil thereby improving our Energy Independence and increasing our National Security. The fact that I now spend that money in my local economy improving it and our tax base goes mostly unnoticed by many.
    If I had to do it all over again, I would! Plug-in cars ROCK!
  16. iLLa Prius
    42
    Lewisville, TX
    yeah, youre right it doesnt seem very cost effective. i have a few future projects planned out. a prius might be one of them. lead acid batteries are just too heavy for most of the ones i have in mind.
  17. Rascal
    Rascal New Member
    37
    Suburbia, Pa
    Hey guys..have you seen this site? Contact Us
    Frequently Asked Questions
    Question:
    How much does it cost to convert my Prius to a PHEV?
    Answer:
    Cost will be $9,750, $14,900, or $19,750 depending on the low-speed EV-only range of 8, 16, or 24 miles per charge.
    Question:
    When can I get one?
    Answer:
    We are taking orders and installing systems now. We can also provide batteries and do-it-yourself support for highly qualified individuals in corporate or other institutions.
    Question:
    Can I install the conversion kit myself?
    Answer:
    No, unless you are trained and qualified to work with high voltage equipment.
    Question:
    Can you convert any Prius?
    Answer:
    We can only convert 2004 or newer Prius Vehicles due to the design of the older models.
    Question:
    Can you convert cars other than the Prius?
    Answer:
    Right now we are converting only Prius vehicles, and will begin development on converting other vehicles next year.
    Question:
    Do you sell converted Prius vehicles?
    Answer:
    We do not sell vehicles. We convert customer owned vehicles.
    Question:
    How long does it take to convert my Prius?
    Answer:
    Our system will be installable in less than 1 day.
    Question:
    Do I take my car to you for conversion?
    Answer:
    Yes, for now. In the future we will be able to install at your site.
    Question:
    How will this affect my warranty?
    Answer:
    We do not modify the factory control systems or traction battery in any way. After-market modifications should not affect the warranty on any component or system not impacted by the modification.
    Question:
    What do you change in the car?
    Answer:
    We do not change any original factory components, systems, or settings. We simply add a large battery and our control system which connects the new PHEV battery to the factory battery periodically to keep the factory battery charged up.
    Question:
    Can I drive completely without Gas?
    Answer:
    Yes, at speeds below 34 mph you will be in EV-only mode.
    Question:
    If I cannot stay in EV-only mode, will a conversion still increase my mileage?
    Answer:
    Yes! When you plug-in and charge up with energy for extra miles, it does not matter if you use those extra miles in EV-only mode, or blended into factory mode driving – you still get those extra miles free of gas consumption overall (see “How It Works†section).
    Question:
    How long does it take to charge – is there a faster way?
    Answer:
    Our PHEV-8 system (which has a low-speed EV-only range of 8 miles) will charge in less than 2 hours from a 120V AC source. We have a charger option available that allows you to plug-in to either a 120V or 240V AC source, and will charge about 3 times as fast - in less than 1 hour. Our PHEV-16 system will charge in about 4 hours (or less than 1 ½ hours with the charger option). Our PHEV-24 system will charge in about 6 hours (or less than 2 hours with the charger option.)
    Question:
    I drive long distances – will I benefit from converting my Prius to PHEV?
    Answer:
    The benefits will be less dramatic but still significant when driving longer distances without charging up. For example, driving 100 miles after charging up a PHEV-24 system will increase your mileage by 30%, to 65 mpg instead of non-PHEV mileage of about 50 mpg.
    Question:
    How much does the electricity cost to charge the car?
    Answer:
    Grid produced electricity costs about 2 cents per EV mile depending on your electric rates. Of course, charging with electricity produced by a solar energy system is even better.
    Question:
    Do I have to plug-in every night – what if I forget?
    Answer:
    You do not have to plug in every night. When your extra battery pack is empty the car operates in factory mode as a normal Prius. Of course the more often you plug in the better your mileage will be.
    Question:
    Are there any benefits at all when driving after my charge is used up?
    Answer:
    Yes! Because you have a bigger battery available, you will be able to recapture more energy during braking and going downhill. Even your factory mode mileage may increase slightly after you use up your charge.
    Question:
    Are the batteries safe?
    Answer:
    We are using NiMH (Nickel metal-hydride) batteries which have a long track-record of safety.
    Question:
    Can I add to the system later?
    Answer:
    Yes. We can upgrade a PHEV-8 to PHEV-16 system, and either to a PHEV-24 system by adding more batteries.
    Question:
    Can the batteries be recycled?
    Answer:
    Yes. Procedures for recycling NiMH batteries are well known and standard practice.
    Question:
    Why are you using NiMH batteries instead of Lithium chemistry batteries?
    Answer:
    Because they are readily available now and have a long track record of safety.
    Question:
    Are you associated with CalCars.org (The California Cars Initiative)?
    Answer:
    Yes. We are partners with CalCars and are working with other CalCars partners to place all control systems into the public domain as EAA-PHEV open source.
  18. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    @ Cheap!,
    What would you say your average mileage range is in boosted MPG? I'm very keen to put Velma through the DIY PHEV route as I've just had to purchase her to replace my EV - whose range, hill climbing ability and speed wasn't up to the work I needed to do :(
    I'm missing the plug already. And I even have two outside power outlets waiting!
  19. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    yea cheap more details would be nice about your setup, i have access to tool just no instructions although the skematics at PHEV eaa is a bit all over the place...
  20. SVPriusFan
    115
    Denver Suburbs
    @Cheap - that is very cool! I know the the Hymotion L5 pack is still on the high side dollar-wise (for me), but it is financially doable. I'm a high-tech junkie and love the idea of being able to go up to 1000-1500 miles on a tank of gas (driving around town and within the limits of the L5 pack of course). Not to mention the environmental and energy independence benefits as well...I just can't pass this up:rolleyes:
    I'm regularly getting 60-65MPG in my car's current unmodified state, and am really excited to see how far I can raise the efficiency with a BREM installed - Whohoo!:rockon:
