Hymotion problem (LED: 3 blinks)
Discussion in 'Prius PHEV Plug-In Modifications' started by snookums, Sep 13, 2010.
  1. snookums
    snookums Junior Member
    85
    16
    The 'Sauga, Ontario
    Good evening PC PHEV gurus,
    On my way home from work today, my Hymotion kinda stopped working as I approached my offramp. I didn't notice at first since the car didn't trow any hell up on the dash. However, I noticed that my charge was a lot higher than it should be for the end of the day, and after staring at the LED I saw that it was blinking slowly.
    I have seen a lot of posts about the 13 and 14 blink issues, but only one reference to the 3 blink issue. But I wonder if mine is the same, since he said "The red light did come on briefly while I was driving and blinked three times." My LED blinks three times, then stays on for 3-4 seconds, then blinks 3 times again... repeat.
    I have already contacted my local Green CHIP, but haven't heard back from them. Has anyone else seen this?
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I've had a 1 blink code. It means a read error with the current sensor. It reset its self after I had the car turned off for a few minutes.
    Does it work fine after the car is turned off for a while?
  3. snookums
    85
    16
    The 'Sauga, Ontario
    Let it sit for 30 minutes before trying again, same blinking. And again this morning, it was on solid for about 3-4 seconds, then went into the blinking again.
    I can't figure out how to reset the unit though. The manual shows me where the breaker is located, but I can't get it to pop out. Do you know how to make it pop out?
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The breaker only pops out when it trips.
    Best thing is to get someone at Hymotion to help you or your installer.
    If you find out what the blink code is please post it here.
  5. snookums
    85
    16
    The 'Sauga, Ontario
    Will do. My appointment is for tomorrow at 3pm, so I will let everyone know what I learned some time tomorrow evening.
  6. snookums
    85
    16
    The 'Sauga, Ontario
    I'm at Toyota right now, and it is the DC-to-DC converter. The pack is being replaced under warranty, but I have to leave it overnight.
    So I wil be without me beloved PHEV for another day. :(
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    OK now I remember about the blink code. David Roper had the same problem.
  8. snookums
    85
    16
    The 'Sauga, Ontario
    Hymotion kit was replaced, looks like the replacement is a refurb of some kind. Only driven it for a day, but it looks like the batteries in the replacement kit have identical capacity and performance to my previous kit.
    Warranty work was easy, no questions about my other mods or the EV button or weak 12v battery... just took out the old one and put in a new one.
