Hyper milers assemble. Looking for winter insulation ideas
Discussion in 'Gen 3 Prius Fuel Economy' started by Hybrid_Motorsports, Nov 23, 2024.
  1. Hybrid_Motorsports
    Hybrid_Motorsports Junior Member
    36
    I got my first hybrid this summer and the cold season is about to start. I come from a hypermiling background where I had a full belly pan Yaris and was able to get 50mpg+
    Now that the temperatures have started dropping, I monitor the engine's temperature with my scan gauge and seeing it drop 10-20 degrees when you start coasting in EV is alarming and explains why these head gaskets fail so often. The best solution I can think of would be some kind of shutter grille that closes when you are in EV mode but it hasn't been cold enough for me to start messing with grill block-offs. For now, I started with insulating the top of the engine and so far, it seems to be helping hold in the heat. No issues with overheating but my intake temperatures are still a little too cold for my liking. I will try to route my intake so it picks up air from the exhaust like I did on my yaris but this will be more challenging since the engine bay is much tighter.
  2. ASRDogman
    ASRDogman Senior Member
    7,885
    4,012
  3. Mendel Leisk
    42,005
    What car is this, a Venza?
  4. Hybrid_Motorsports
    36
    Luxury Prius, it's a CT200h. I don't know why the forum doesn't have it as an option to select on my profile yet you can put Tesla or Leaf..
    bisco and Mendel Leisk like this.
  5. bisco
    52,477
    you wouldn't get any responses there anyway, so you're better off
  6. Mendel Leisk
    42,005
    Here's something I've done, leave it in year 'round, both sides of course:
    pic to come
    Once temps drop to 4~5C I'll put similar pipe insulation tube, on 50% of the lower grill. If it drops and stays below 0C I'll go 100% (a second tube).
    Consider also the block heater?
    #6 Mendel Leisk, Nov 24, 2024
    h1ph0panonymous likes this.
  7. Hybrid_Motorsports
    36
    The CT's engine bay is pretty well sealed. I only had to add a rubber strip on the headlight where the fresh air for the intake comes in. I may look into a block heater but what I use is an oil pan heater that sticks on the bottom of the pan since I don't really mind not having heat but I like the idea of having warm oil for the engine on cold start up.
    Getting up to temperature isn't really what worries me, it's keeping that temperature up and not having it drastically drop every time EV mode turns on.
    #7 Hybrid_Motorsports, Nov 24, 2024
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,634
    6,661
    Texas Hill Country
    It is an important factor recognized by some at Toyota
    This engine does drop temp quickly but I doubt blocking the grill will help. It does in 90f ambients as well; I documented 40f drop in hot ambients. The engine water pump shuts off immediately.
  9. Hybrid_Motorsports
    36
    I've also started using the B mode when I first take off on a cold day. If I keep it in D, the engine will keep shutting off when I get to a stop sign even though it's stone cold. I like the fact that in B mode, the engine will stay running and warm things up faster.
  10. bisco
    52,477
    will it shut off if you have the heat on?
  11. Hybrid_Motorsports
    36
    Driving a hybrid is so much work lol. I keep the heat off for now and just use my heated seat because it affects how fast the engine gets up to temp. It does keep the engine running longer but it still shuts off, maybe its not cold enough outside yet? Putting it in B mode seems to be a sure way to keep the engine on but maybe once it gets colder outside, leaving the heat on will be enough to keep the engine running.
    #11 Hybrid_Motorsports, Nov 26, 2024
  12. Hybrid_Motorsports
    36
  13. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    B mode is designed for engine braking to get rid of charging when going down hill not to exceed 60% soc. Engine stays on to waste charge, you should just for a gasser instead.
  14. Hybrid_Motorsports
    36
    I wasn't serious obviously and I enjoy the challenge. I'd just like to keep my engine healthy during the cold periods and not need a head gasket every 150k. If it comes to that then so be it but I'm just experimenting here.
    #14 Hybrid_Motorsports, Nov 27, 2024
  15. Hybrid_Motorsports
    36
    Turned the heat on today and the engine did stay on a little longer but it still shuts off at the first red light when the coolant hasn't even reached 55F. Leaving it in B really did the trick but now I'm worried the extra load is doing more harm than good. Engine braking a stone cold engine doesn't feel right.
  16. Mendel Leisk
    42,005
    Maybe overthinking it?
    Again, I'd look into block heater install. The part is about $90 CDN. Install you'd have to check, but likely at least $250 CDN. Having the CT200 is "might" be different, but I doubt it, think the engine is identical. This is the part number I got, when I replaced the one we'd had installed back in 2010:
    PU140-00905
    Second time around I did the install myself, and it was a struggle, simple because there's so much cables/hoses/brackets in the way. There's a link in my signature with more info. (on a phone turn it landscape to see signatures)
  17. Hybrid_Motorsports
    36
    Thank you, a block heater is what I need. I tried looking for one with the part number you gave but there is nothing for PU140-00905 on Toyota websites and Amayama. All I could find was for part PK5A4-08J14
    Toyota Block Heater - Prius PK5A4-08J14 – Jackson's Toyota
    PK5A4-89J16 - Block Heater Brantford Toyota Parts
  18. Mendel Leisk
    42,005
    Yeah part no for the one we had installed in 2010 was different from the part I got through local dealership, just a few years back.
    Second link you posted is significantly cheaper. I'd note the two part no's, then phone a nearby-to-you dealership parts department. Let them figure out the correct/current part, check against the noted numbers but go with their recommendation. Price around $90 is the usual.
    Hybrid_Motorsports likes this.
  19. Hybrid_Motorsports
    36
    QUOTE="Mendel Leisk, post: 3496308, member: 69191"]Yeah part no for the one we had installed in 2010 was different from the part I got through local dealership, just a few years back.
    Second link you posted is significantly cheaper. I'd note the two part no's, then phone a nearby-to-you dealership parts department. Let them figure out the correct/current part, check against the noted numbers but go with their recommendation. Price around $90 is the usual.[/QUOTE]
    Looks like Toyota and Lexus have discontinued the block heater and they can't get it for me. I'm going to keep using the stick-on pads on the bottom of the oil pan for the oil and as for the coolant, I will try this Termo lower radiator hose heater. It probably won't be as good as the oem block heater but it will be better than nothing.
  20. AzusaPrius
    AzusaPrius Senior Member
    2,244
    933
    @Hybrid_Motorsports
    The ICE at any outside temps will never shut off with the coolant at 55F.
    With ECO mode on, the ICE will be warmed up and shut off at 104F.
    With ECO mode off the ICE will be warmed up and shut off at 124F.
    Keeping the heater ON with temp set to HI will keep the ICE on longer but once you are past 104F and 124F you should be on your way to getting to 185F
    Also when you do not have ECO mode ON, there is a 700-800 watt heater that helps with the heat.
    #20 AzusaPrius, Jan 4, 2025
    Bill Norton likes this.
