Hypermiling: Prius G3 versus Prius C
Discussion in 'Gen 3 Prius Main Forum' started by Troy Heagy, May 15, 2013.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    The C has a much smaller engine. If a hypermiling driver drove 45-55mph, would the C be able to beat the standard prius in fuel economy?
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    There's more at work than the engine size. The c also has a smaller battery and a less slippery shape.
    That being said, it's possible. The engine in the c is the same size as was used in the Gen 2 standard Prius.
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    One of the reasons Toyota upped the engine size to 1.8L was to reduce the engine RPM's at highway speed to improve highway MPG's.
  4. Troy Heagy
    Troy Heagy Member
    1,218
    Got it.
    Just seems odd that making the engine bigger would increase fuel economy. Normally you think "make the engine smaller, less cylinders, less moving mass" in order get better efficiency. All the highest MPG cars in Europe are tiny three-cylinder versions. (The highest being the Lupo TDI at 80mpg and only 1.2 liter.)
  5. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    What the HSD excels at is utilizing the engine as much as possible in optimal conditions (minimum engine speed with low manifod vacuum/high loading). At higher speeds the power needed can't be met by a smaller engine without speeding the engine up to the point of much less efficiency.
    With its lighter vehicle weight the c's engine/traction motor/battery sizing work very well at "city" speeds. At highway speeds it works well but not as efficiently because of the power needed to push it through the air.
  6. Troy Heagy
    Troy Heagy Member
    1,218
    Good point. I guess it also helps that the G3 has no belt-driven accessories dragging on it, like the C and previus G2 had.
    In one youtube review a guy asked, "Why didn't they put the 1.8L engine in the Prius c? That was the original plan but apparently Toyota changed their minds." Anyone know why that happened?
  7. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    The C has no belts.
    X
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    In general the c has better fuel efficiency off the freeway so if you avoid high speeds then you should beat the Prius easily.
    walter Lee likes this.
