Hypermiling Up Hills?
Discussion in 'Gen 3 Prius Fuel Economy' started by PriusMPGenius, Apr 18, 2019.
  1. PriusMPGenius
    PriusMPGenius Junior Member
    85
    82
    Kingston
    We live at the top of a very steep and long hill that kills my hypermiling scores. Any suggestions to get the best possible fuel efficiency? I've been going up it at about 25mph's but I wonder if applying more accelerator and spending less time driving up the hill is more efficient?
  2. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    I would guess that the slowest you can drive with the ICE running would be the most economic. Or maybe your drive down will fill the battery again, then I'd try to get the battery down to its lowest level.
  3. orenji
    orenji Senior Member
    5,884
    3,486
    Park at the bottom of the hill and walk up :)
    Uberdriver2710, Steves895 and fuzzy1 like this.
  4. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Build up as much speed as you dare before starting the hill, then keep a dead foot on the pedal, allowing the car to decelerate all the way to the top of the hill. That's how it's done.
  5. PriusMPGenius
    85
    82
    Kingston
    Problem is there's a stop sign at the base of the hill so I'm starting the climb at a dead stop.
  6. fuzzy1
    10,254
    I don't believe that there is much you can do on the uphill, other than to avoid the hill entirely. :)
    The downhill side is where most people make or break their results. And steep ones are built to break the numbers.
    CR94 and BruceInOKC like this.
