Hyundai Sonata Hybrid Officially Revealed
Discussion in 'Other Cars' started by ljbad4life, Mar 31, 2010.
  1. ljbad4life
    ljbad4life New Member
    365
    24
    The official specs for the Sonata Hybrid. 37city/39 highway. While it didn't top the fusion in the city it does beat all other sedans on the highway.
    Strangely the hyundai can't power itself under electric power at low speed, but can travel up to 62 mph on electric only. I think the author might be confused.
  2. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Not much doubt about confusion in the article. Like comparing the Sonata's 40 horsepower electric motor with the Camry's 141 hp "motor." Not sure I want a conventional automatic transmission either.
    Still improved gas mileage and reduced emissions are always a good thing. As well as competition to keep things moving forward.
  3. ljbad4life
    365
    24
    Yeah the electric motor on the camry is not 140hp! that is close to a Tesla roadster that does 0-60 in less than 4 seconds. The total output for the HSD is 140Kw but that does not translate directly into horsepower.
  4. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    ASSIST hybrids have a very limited amount of electricity available, since there's only a single motor which is integrated directly to the engine.
    FULL hybrids demonstrate a significant advantage by having a second motor and a power-split-device which results in an ample amount of electricity being available in comparison.
    Apples to Oranges.
    Sonata is one type and Camry/Fusion/Prius is the other.
  5. ljbad4life
    365
    24
    well this ASSIST hybrid is wiping the floor with a certain FULL hybrid in terms of MPG. Where's the advantage? :)
    I know the advantages of Full vs assist, but there is no advantage if it doesn't improve mpg.
  6. john1701a
    12,755
    5,245
    57
    What's the emission rating?
    What happens in real-world driving with the A/C running?
    What happen in heavy stop & slow driving conditions?
  7. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    I think it's interesting that so many of the "specs" are "estimated." How can you say you beat another car's specs with an "estimate?"
  8. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    The Hyundia Sonata Hybrid (HSH) is not an assist or mild hybrid. It is a Parallel only hybrid though, which is obviously less advanced then the power-split-device (series/parallel) hybrids like the Toyota and Ford systems.
    In effect the HSH is a third category if you consider Ford/Toyota/GM 2mode as full hybrids and Honda and first gen GM hybrids as assist or mild hybrids.
    Since there are plenty of quality competitors in this class, price is going to matter.
  9. hampdenwireless
    1,104
    86
    Baltimore MD
    The AC is electric like the Prius. Heavy start/stop will penalize this setup a bit but it will do great in slow driving.
    There are some design advantages to the HSH. One is the direct injection engine. This is the first direct injection Atkinson cycle engine I have heard of. The other is the car is designed around a 4 cyl engine only, unlike the Camry hybrid or the Fusion hybrid.
    From the article - "Weight savings extend to the whole car as well. Because Hyundai engineered the new Sonata without the possibility of installing a V6 engine it was able to reduce the mass of the structure. The curb weight of the hybrid Sonata is just 3,457 pounds, some 263 pounds less than the Fusion, which is likely to give it a performance advantage over the Ford. "
  10. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    I do note that a big selling factor for the Prius (my reading, not the salesman) was the simplicity of the CVT which reduced my concern about the cost of battery replacement. If I wasn't quite happy with what I have, it might turn me away from HSH.
  11. john1701a
    12,755
    5,245
    57
    What about the supply question? Where will the electricity to run in come from?
    In other words, how often is the battery-pack fed?
    With FULL hybrids, you've got recharging taking place pretty much whenever the engine is running. How does this "parallel" approach differ from ASSIST? Since there's still only just one motor available, abilities are limited. (You cannot assist & recharge at the same time.)
  12. john1701a
    12,755
    5,245
    57
    It's statements like this I take issue with...
    ...since we know that's not true.
    It could be more efficient. After all, having more gears typically is. But the speed part is a crock. The competition can offer that same 62 MPH speed and plans to. That's what will be available from the plug-in Prius.
  13. hampdenwireless
    1,104
    86
    Baltimore MD
    I don't think the speed part is a crock, it does seem to be correct. Hyundia can provide full electric at high speeds when HP demand is low without the electrical transitions involved in the power split device. That of course does not mean its better.
    It seems to be designed for the highway. It can not charge the battery and assist at the same time. The total electric power is lower then HSD provides so its city performance is going to rely more on the gas engine. To make this work better they have worked to keep the car weight down compared to the others in its class.
  14. hampdenwireless
    1,104
    86
    Baltimore MD
    Good question. I do not see how that will work well with electric fed AC, with AC on the electric motor may have to work as a generator more often then ideal.
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    It is an assist electric AC. Sound like how it is in HCH.
  16. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    HSH is very aerodynamic (0.25 cd) like the Prius. It is bigger outside and the ICE is bigger. Highway MPG is 39 MPG (not official yet) versus Prius 48 MPG. That's pretty good.
    We don't know the compression ratio for HSH Atkinson ICE. I wonder if it would be close to Prius' 13:1 ratio.
    If you compare hybrid and non-hybrid versions, the weight gain for HSH is about 250 lbs. TCH is about 360 lbs. Fusion Hybrid is 435 lbs.
  17. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    HSH has a six speed step gears with very tall 4th, 5th and 6th. That will have delay in downshifts passing cars on the highway.
  18. Trollbait
    11,563
    With the torque of the motor, it may not need to downshift to pass in most situations.
    There is another motor/generator on it. The auto stop function is handled by a (very) mild system like GM's. There may be some electric generation while the traction motor is running. We didn't get much in the way of actual technical details.
  19. ljbad4life
    365
    24
    maybe you didn't see this from hyundai's press release:
    And:
    That sounds like more inline with a full hybrid than a mild hybrid (even though it might not be designed like the HSD).
  20. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    What's going to be confusing for Hyundai customers is that they're using the term Blue Drive for high mileage non-hybrids too...
