I’m assuming this is a bad thing?
Discussion in 'Gen 2 Prius Main Forum' started by Autobon7, Apr 15, 2022.
  1. Autobon7
    Autobon7 New Member
    Alton, IL
    Purchased the Dr Prius app and used for the 1st time yesterday. Is a 07 with 221xxx miles. Just trying to wrap my head around all the data……..since this is my first hybrid.
  2. ChapmanF
    17,348
    What exactly was happening at 5:24 PM on Thursday? That looks like a moment when the battery was taking a high rate of charge.
  3. Autobon7
    Autobon7 New Member
    Alton, IL
    This was simply in stop and go traffic and happened several times while braking when approaching a red light
  4. ChapmanF
    17,348
    Had you just come off a longish downhill or something? The state of charge is a little higher than what the car shoots for most of the time.
  5. Autobon7
    Autobon7 New Member
    Alton, IL
    no downhills to speak of. At one point all the packs turned red for just a second so I wasn’t able to get a screen shot. I’ve driven the car for 1100 miles since I bought it and zero codes. Just out of curiosity I bought the veepeak unit and the Dr Prius app. Car has averaged around 49 mpg on 3 fill ups. The seller did say that I should buy a new 12v battery soon but have not had any issues and carry my jump pack with me.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I would say you caught your screenshot during regen braking.
    and you still have no codes. The car is doing its thing. Be happy with it and drive. If you monitor it frequently, you'll get used to how it acts under various situations. The Prius is a very smart car, it will definitely tell you when it has a problem.
    #6 TMR-JWAP, Apr 15, 2022
  7. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    I’ve seen this too on regen braking. Otherwise my battery performs well with sub 25 IR and 0.1v differential voltage amongst cells.
    I think it’s an artifact of the Dr Prius app. Would be nice if Dr Prius had an instruction manual. If they have one, would like a link.
  8. Autobon7
    Autobon7 New Member
    Alton, IL
    I sent them a note asking for some kind of guide or instructions. Really don’t want to watch 30 different videos to understand what the data means. Will post their response.
    Another likes this.
  9. Wrecit
    Wrecit Active Member
    177
    113
    Pittsburgh
    2001 Prius
    I
    As someone who had a track battery go (as many have lol) if your getting 49mpg then you should be good for a while. Dr Prius is great but if you don't understand the readings fully it will freak you out at times (well it freaked me out)
    First sign that track batt is going is usually a drop in mpg. Example here in Pittsburgh with alot of hills I can get 36-52 mpg on a tank depending on where I drive with most tanks being about 38 mpg. This winter before my battery went I was lucky to get 29 (though it was deep freeze and ran heater high which probably over stressed the battery)
    If you live in "flat lands" and are currently getting 49 then get a tank below 40 maybe plug in the old doctor for a tank or 2 and check consistency of read outs.
    Unless you are a heavy hybrid geek that has a solid knowledge of the system I would recommend not running the Dr all the time because it will drive you batty. I ran it for my first 3 months straight and every time I parked I knew something new was wrong with baby. Then using advice and info from Prius chat I learned I was to paranoid lol
    Autobon7 likes this.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    The big thing on Dr Prius is the "voltage diff" reading. As long as that consistently stays at 0.3V or less, then the car is happy. If it goes above that for a bit, the HV battery ecu will take notice. If voltage diff goes too high for too long, then the ecu will set codes. 0.2 to 0.5V diff for a few seconds during heavy accel or decel is not unusual.
    (The higher the voltage diff, the less time it takes to code- for example if the diff is 1.5V from a shorted cell, I would expect a code within a few seconds).
    State Of Charge - with "normal" "steady" driving the car will maintain 60-70% - about 5-7 bars on the center dash display battery gauge. Stop and go driving (esp with A/C) can let that go to 45% SOC (2 bars).
    Your car looks to be fairly normal right now. Watch the data you have now, if the data changes from what you see now, then it might indicate a problem.
