I’m having problems with my 2008 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by jprius!, Aug 4, 2024 at 6:42 PM.
  1. jprius!
    jprius! New Member
    Friday
    Kennesaw, GA
    What’s up, everyone? I just wanted to see if I’m the only one with this problem, or if it’s just my car.
    The A/C stopped working a few days ago, in this summer heat. I don’t know if something might be leaking from the car (taking it to the shop in a few days)
    My phone would not connect to make calls, and yesterday the whole multimedia screen went black.
    I disconnected the 12v battery and reconnected it after a min, just to see if it was related to the problem. Started the car and multimedia system was working, back to normal.
    Do yall think it’s a battery related problem?
    49,579
    doesn't sound like it. you can get a free 12v load test at many auto parts stores, how old is it?
    any trouble lights?
  3. Tombukt2
    Tombukt2 Senior Member
    9,313
    1,627
    Durham NC
    Do you have a red triangle or orange lights on the dash My guess will be probably the inverter pump is on the way out
  4. dolj
    dolj Senior Member
    7,691
    3,890
    Wellington, New Zealand
    ... or the MFD is on the way out - intermittent for now but will get worse as time goes on.
    BTW, it wouldn't hurt to fully charge your 12 V battery and test it with a tester.
