I’m sorry.. I’m positive this has been posted before but I can’t find in through many search combos.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ToriM, Jan 1, 2020.
  1. ToriM
    ToriM New Member
    Oregon
    New to us 2011 Prius 5. Regularly maintained at a dealer before us purchasing, in PNW. nightly temps dropping to about 30, daytime is up to upper 40s-50s.
    the battery soc hasn’t changed level very much in the last few trips around town. 5 miles or less. Computer is stating 43~mpg, and after 240~ miles on the trip since fill up, we’re sitting at a half a tank. The tank seems very low to me, though I know it is quite misleading. It seems like the ice is kicking in often and not staying off very much. Am I being paranoid about it? Is it because of the colder temps and shorter trips that the battery doesn’t seem to be discharging and recharging?
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Ice is coming back on often because it’s trying to keep itself at optimal temperatures in colder climates. With short drives in cold weather, it will be a sand pounder for a bit. These vehicles are best when driven far for long periods w/o uphills. For the time being you should check your tires psi to see if it help improve mpgs
    ToriM likes this.
  3. ice9
    ice9 Active Member
    581
    343
    norfolk va
    2018 Prius
    No. It's because the ICE (internal combustion engine) is running more. Colder temperatures will reduce your MPG significantly for short trips in an urban environment. This is because the ICE is running and consuming fuel in order to warm up during a larger proportion of the distance and time traveled. MPG is greater during the warmer season because the ICE warms up more quickly.
    See Gen3 Warming up stages by ken1784.
    During the summer, when temperatures are seldom below 70 degrees F, I can usually get between 65 and 70 MPG commuting around town using hypermiling techniques. During the winter, this drops down to between 50 and 55 MPG. Without hypermiling, MPG will typically be what you are experiencing for short commutes - somewhere between 40 and 50 MPG. On longer trips (greater than 20 miles) you will notice that your MPG will return to normal during the later part of the trip, even when it is cold. That is because the ICE usually takes only a few minutes to warm up, after which the vehicle operates in the higher efficiency states (described in ken1784's post) during most of the trip.
    It is reported here in PC that using an engine block heater improves fuel efficiency for short trips, but I cannot vouch for this myself since I have never used one.
    ToriM likes this.
  4. fuzzy1
    10,167
    It's cold. It's wet. It's winter:
    Why mileage gets worse in winter
    And your trips are short, too short for the engine to fully warm and then start getting good MPG. For short winter trips, your MPGs seem normal:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
    Your short trips are also not giving much time for the engine to push the traction battery SOC up to its normal 6 bars. Low speed stop-and-go city traffic tends to drag it down, while steady highway or arterial speeds tend to help restore it.
    The fuel economy questionnaire above was written mostly for new drivers with fresh young cars, so it doesn't cover older-car issues such as excessively dragging brakes, or EGR clogging (a head gasket risk, not an MPG issue).
    How many miles are on this car?
    As for the tank getting low, note that the bottom of the fuel gauge is not at the real bottom of the tank, there are a couple gallons of safety margin left below the last warning and beyond Distance-to-Empty's first showing of 0 miles remaining. But don't depend on this to go any specified distance. While the margin should be good for about 100 miles of single-trip distance in the best MPG conditions on warm dry flat roads, there are very many ways for it to come up very short of that, and winter and mountains present many of those conditions.
  5. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    ToriM and Mendel Leisk like this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Yes and yes.
    AND.....unless you are coasting down the side of a big mountain, the gas engine is the ONLY source of energy to make the car go.
    The gas engine supplies the enerty to turn the wheels.
    The gas engine charges the HV battery......which then later helps turn the wheels.
    The gas engine gives you heat when it is cold.
    There is no magic with a hybrid. It is just a bit more efficient.......in some/most situations.
  7. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    One more thing is that the cabin heater — the thing that blows warm passenger air — requires heat generated by the engine.
    If your cabin heater and ICE are both OFF, the instant you turn on cabin heat, the ICE will start up. The AC is electric but the cabin heater is not.
  8. Rebound
    3,964
    2,613
    Portland, OR
    Delete
    #8 Rebound, Jan 4, 2020
  9. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    And then winter blend gasoline.
    Rebound likes this.
