I’ve Been Driving On P0A80 For 6 Months
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Percy2004Prius, Jan 31, 2021.
  1. Percy2004Prius
    Percy2004Prius New Member
    Fredericksburg VA
    Hi There Happy Snow Day, I’m Percy And I Have The Prius 2004 Without Navigation Color Black With 297,917 Miles . First Car I’ve Own Since 2004. I Have Been Driving On P3000 P3017 P0A80 C1310 C1259 For 6 Months With The Fan On. I Loses Engine Power But I Reset It With A Code Scanner If Needed. Friday The Car Wouldn’t Reset P0A80 P3017 P3000 C1259 C1310 I Also Had P0441 P0455 But That Was 1 Month Ago When I Got The Code. I Took It My Mechanic To See If Any Other Codes And Found The Same Codes I Found. Any Ideas On Why The P0A80 P3000 C1259 P3017 C1310 Won’t Reset But P0441 P0455 Will?
    P0441
    P0455
    P3000
    P3017
    P0A80
    C1259
    C1310
    B1421
    12V 12.90 OFF 14.30 ON
    BB1 15.40
    BB2 15.44
    BB3 15.38
    BB4 15.49
    BB5 15.43
    BB6 15.48
    BB7 14.04
    BB8 15.31
    BB9 15.18
    BB10 15.30
    BB11 15.41
    BB12 15.50
    BB13 15.28
    BB14 15.00
    RR1 0.30
    RR2 0.30
    RR3 0.30
    RR4 0.30
    RR5 0.30
    RR6 0.30
    RR7 0.30
    RR8 0.30
    RR9 0.30
    RR10 0.30
    RR11 0.30
    RR12 0.30
    RR13 0.30
    RR14 0.30
    #1 Percy2004Prius, Jan 31, 2021
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    If the HV battery is still OEM and untouched, you may want to service/rebuild it. Otherwise it may be time for a new HV battery.
    300k is a good run, are you the original owner and did you ever clean the HV battery fan?
  3. ChapmanF
    17,349
    Clearing any trouble code without doing anything about the problem that the code is telling you about only means the code goes away for as long as it takes the car to notice the problem is still there. Some problems get checked for more often than others.
    The evaporative emission system codes might not come back until the next time the car does an EVAP self test. It's even possible you had a P0455 because of something like a loose fuel filler cap, and maybe you have put it back on tighter since then, and so the code really won't come back.
    Meanwhile, the battery ECU tracks those module voltages all the time, so if you tell it to clear the P0A80 and you haven't done anything to fix the problem, it pretty much knows in real time that you're bluffing.
  4. ozmatt
    ozmatt Active Member
    631
    260
    Australia
    Hi you probably have electrolyte leaking out some of the battery modules causing high voltage leak therefore the car won't ready
    Time to replace battery or at least swap some bad modules and clean everything up
    If the back of the car has been getting wet you may find the p3000 relates to corroded and maybe burnt plug on voltage sensing harness and the connector in battery ecu, so a good used battery pack complete with wiring and battery ecu would be easiest choice
    Cheers
  5. ChapmanF
    17,349
    Codes would be different.
    ozmatt likes this.
  6. ozmatt
    631
    260
    Australia
    Yeah true and voltages are too close, forget that sorry! lol
  7. Percy2004Prius
    Fredericksburg VA
    Well so have I damaged my hv battery? You think the voltages have something do with battery ecu?
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    As ChapmanF pointed out, clearing the codes earlier gave you a temporary reprieve until the HV ecu figured out that block 7 still had problems. During this time the batteries deteriorated more and more. Now one of the modules in block 7 has failed completely (the much lower voltage shows that a cell has shorted). The ecu sees this and immediately sets all those codes- which all point to the failed HV battery.
    Time to think about what you want to do now. Sell the car, replace the pack, attempt to repair- your choice (given that it has a bunch of miles, was abused for 6 months and has very wide range of static voltages- this pack will need a lot of work to function again).
    The 2 EVAP system codes (P0441 and P0455) can only set after the engine computer has run the monitor tests for the EVAP system and has had it fail - two times in a row. Depending on the weather (esp the ambient temperature) and how you drive, it can take weeks before the monitor completes and passes or fails(and sets a code). The P0455 could be a loose gas cap, or it could be a failed fuel tank assembly. The P0441 might be a purge valve, or a fuel tank pressure sensor, or something else. Doesn't matter until you fix the HV battery.
    #8 mr_guy_mann, Jan 31, 2021
  9. Percy2004Prius
    Fredericksburg VA
    I drive it 30 minutes from my home in southern Fredericksburg VA TO Stafford VA
  10. Percy2004Prius
    Fredericksburg VA
  11. mr_guy_mann
    3,966
    1,914
    NJ-USA
    OK, what does that have to do with your problem? You have to do something with your HV battery. (there have been a couple posts about people continually clearing codes on a failing pack and having one or more modules burst with a bang).
  12. Percy2004Prius
    Fredericksburg VA
    I was wondering if 30 minutes every week day would kill the hv battery that has P0A80 Code For 6 Months
  13. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Given the list of DTCs in the first post, it would appear you're already heading down that path.
    Were any of the above replies unclear, or confusing? (perhaps this one : I’ve Been Driving On P0A80 For 6 Months | PriusChat
  14. ozmatt
    631
    260
    Australia
    people that clear codes and keep driving on bad batteries tend to think clearing codes fixes anything!
    I bought a broken down car last year that I later figured out had ran out of fuel (amongst many other things!) to ad confusion it had been refilled before I got it, and no one mentioned it to me!
    clearing codes won't fix that and if you keep trying to clear and ready a prius with no fuel it will fry the fuel pump and run hybrid battery flat in no particular order
    Just a thought
    #14 ozmatt, Feb 2, 2021
  15. ChapmanF
    17,349
    In another way of looking at it, you've been conducting an experiment into how long you can get away with clearing codes on a progressing battery failure without fixing it, and the experiment is shaping up to give you the answer "about six months" ... though you could wait for the loud-bang-and-bad-smells from the back of the car to find the outside limit.
    Note to other readers: it's all very situation dependent ... don't assume you would also necessarily get "about six months" as the answer.
  16. ozmatt
    631
    260
    Australia
  17. mr_guy_mann
    3,966
    1,914
    NJ-USA
    Having used the car for many years and many miles has "killed" the HV battery. It has a finite life span, and will wear out and fail at some point. It was dying 6 months ago- resetting the ecu again and again put the final nail in the coffin.
    It is like asking "I wonder if turning the headlights on would cause the bulbs to burn out?"
    #17 mr_guy_mann, Feb 3, 2021
    Moving Right Along likes this.
