I BE BACCKK! Flourescent fixture issue
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Apr 8, 2020.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,135
    1,560
    Iowa
    Some of you whom have memories, may recall I did a very stupid thing just about this time last year and called in an electrician to fix a problem that was not a problem.
    That issue was a light switch all of a sudden stopped turning on the floor lamp in the den -- turned out a relative (he finally admitted it) moved the plug from the top outlet to the bottom?? and all it took was putting the plug for the light back into the top position (if that makes sense:sick::sick:)// You can find the entire shameful tale here (but I suggest you skip it just to spare me....).
    Embarrassing end to Electrical issue | PriusChat
    So, now, in my bedroom closet, there is a ceiling mounted 48" flourescent fixture that is about 11 years old and takes two tubes. One tube burnt out long ago and I removed it, but the second tube still worked. And that was plenty of light by itself.
    In the past few months, said left-over tube would sometimes flicker for a moment -- only a moment and only sometimes -- but then go on.
    The light is never on for more than a couple of minutes at a time, btw.
    Anyway, this morning, it went on and then it went right out. And would not come on again.
    I risked life and went and bought new tubes installed one and it came on for a moment as I was twisting the tube, but no matter what I did after, it would not come on again. I was not planning on installing the second tube ( they come in packs of two), but I ended up installing the second tube.
    I have been twisting and cursing and cannot get either tube to light.
    Yes, I looked at the breaker panel. I kept flicking the NEW (installed in December) light switch. Nothing.
    So, I tried YouTube, etc., but all I can find is people who cut off the ballast, remove it totally and test it. First, if it is the ballast, I think I can buy a whole NEW fixture for cheaper than replacing the ballast.
    Second, is there a way to test at either one of the ends of the fixture -- you know where you stick in the prongs and twist -- and see if electricity is getting there?
    If so, how? In other words, help!
    I suppose I could just replace the whole fixture. But if not necessary I would rather avoid going out, if possible.
    kris
    48,962
    i'm no expert, but i have always had to replace the ballast if new bulbs didn't work. and you're right, a new fixture is a better idea.
    can you order something led on line?
    srellim234 and cyberpriusII like this.
  3. Prius Maximus
    Prius Maximus Senior Member
    930
    775
    Northeastern IL
    Replace 'em with LED bulbs. You'll never have burned out bulbs again, they won't fade over time, they run cooler, and they're cheaper to use. I did mine several years ago. Bypassing the ballast requires rewiring the fixture with new sockets, but it wasn't difficult at all.
    Now they have direct plug-n-play LED replacements so you don't have to re-wire:
    4 ft. T8 LED Tube - 1650 Lumens - 13W - 4100K - Plug and Play - LifeBulb LBT8F1641B-CS | 1000Bulbs.com
    That's probably the easiest way to go, but those bulbs won't work without a working ballast, so they won't help you.
    I would re-wire the fixture and use a standard LED bulb:
    toggled 48 in. High Output 23-Watt Cool White T8/T12 LED Light Bulb-A423-40230 - The Home Depot
    edthefox5, fuzzy1 and cyberpriusII like this.
  4. cyberpriusII
    1,135
    1,560
    Iowa
    I don't know if I have a working ballast. And I do not want to pull apart the fixture and remove the ballast to find out....
    Nor do I know how to rewire the fixture. Although I am sure I could figure out how to replace the whole thing.
    But seriously, is there a simple way to find out if the current fixture is the issue, or not?
  5. Prius Maximus
    930
    775
    Northeastern IL
    cyberpriusII likes this.
  6. cyberpriusII
    1,135
    1,560
    Iowa
    It's rapid start. No starter.
  7. ChapmanF
    15,094
    If it's fluorescent, and the tubes aren't the problem, the ballast is. But these days fluorescents are kinda dinosaurs anyway. (I guess sometimes it could be one of the sockets, but those are coin-lands-on-edge odds.)
    I would look for a way to order online a nice LEDish fixture to replace it. Or maybe compare the price to a kit that retrofits it to LEDish "tubes" and requires taking the ballast out. That isn't hard, and if I remember right you have several hounds to watch over your shoulder and make sure you don't mess up. I'm sure the retrofit kit will have instructions that make it straightforward.
    If the existing fixture is somehow nicer than a bare-bones striplight and you like it, then keeping it and retrofitting might make sense. If it's just an old ugly striplight anyway, then this could be the opportunity to find a nice LEDish one that's nicer.
    cyberpriusII and Trollbait like this.
  8. mikefocke
    3,638
    1,626
    Sanford, NC
    And it could be the light switch itself. Oddly, in my house it is the three way switches that fail, never the simple single pole ones. Been in a new house 13 years, will be on my 4th sets of three way switches in some locations.
    Walmart and Costco sell LED bulbs for the common length of fluorescent fixtures. Love em.
    So what is the best way to attack this..
    My approach would be
    1. Are you sure you have rotated the tubes correctly?
    2. Disable the fuse/breaker that controls the circuit.
    Replace the switch. Re-engage the breaker. See what happens. Cost maybe $3-4.
    If that works, you are done.
    3. If not then breaker off. Swap the fixture. ~$20. Easier than debugging the starter.
    You are probably better off throwing parts at the job than paying for labor hours.
  9. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Running a 2 light fluorescent fixture with only one light is a good way to burn out the older type of ballasts. I do not know of the newer electronic ballasts behave the same way.
    Replace the fixture.
    San_Carlos_Jeff and cyberpriusII like this.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    Seriously......you have ALL the evidence that you need, probably.
    The fixture is getting power because it flickers.
    The bulbs are new.
    The only thing left is a bad ballast in the fixture.
    And as you surmised, replacing the ballast is a royal PITA.
    A new fixture is needed.
    IF......you don't really need a lot of light, a simple one or two conventional style bulb fixture would work, with one or two LED bulbs.
    No matter what you do, you will end up with two spare long bulbs because almost all new fixtures come with bulbs.
  11. cyberpriusII
    1,135
    1,560
    Iowa
    Hey, thanks you all!!
    As you can tell, electrical work is not my forte.
    So, husband came home and and he performed his alcohol soak to assure he is not infected -- somehow that includes a pint of chocolate porter.
    But then -- he had what seems to be a good idea.
    He called a local neighbor (local being relative) and asked if her thrift store had any fixtures. Apparently, they have shelves of them. And she said she is sure there are probably a number of ones that would be more or less an exact fit.
    And, while their store is closed right now because of the virus issue, since I volunteered there for years, she said she would meet me Thursday and let me have whatever one I want for free.
    Now, of course, I will donate $40 or so -- which is probably more than a new one costs -- but it is a good cause.
    Now, hope the replacement goes on easily -- and works.
    Oh, I do like the idea of an LED replacement, but I already have the tubes and I can't return them....
    Thanks again,
    krsi
    Trollbait likes this.
  12. Trollbait
    11,325
    Something like this should work.
    I have one with two metal probes that could be shoved into the sockets. It is old enough to not have an LED for the light. You don't want an actual circuit tester. Those have batteries in them, and are for testing things when they aren't hooked up to a power source. Of course, a multimeter would work.
    But I'd just go to LEDs. Should be straight forward changing the fixtures. A retro fit shouldn't be much harder. You'd be cutting wires inside the fixture inside it instead of outside. Ease depends on how easy to get inside it, and how tight that inside is.
    LEDs do fade, but over a period of years to florescent's months.
    I stopped seeing starters in aquarium fixtures during the '90s:) Any old ones I still have left I plan to wire with the electric ballasts from old screw in florescent bulbs. Which I don't recommend here because it means soldiering.
  13. cyberpriusII
    1,135
    1,560
    Iowa
    BTW,
    This thread was worth it for me if for nothing else, now I know about LED tubes.
    Had never heard about them.
    Have replaced the reverse lights on my Prius with LED and love them (and a pair was only $11). Also, replaced an outdoor flood, an indoor staircase, as well as a kitchen work area lights with LED and they are great. Hoping they last.
    kris
    Prodigyplace likes this.
  14. Prius Maximus
    930
    775
    Northeastern IL
    The ones that were in my house and my parents house still have them. I didn't know how old Cyber's fixtures were, and
    (Make that a geologist - the common redshirt)
    Thanks for the info, though, I didn't know those were obsolete. Could explain why they were so expensive when I last replaced them...
  15. Trollbait
    11,325
    I don't know when the old tar ballasts stopped being used, but everything is electronic now. If you still have the old ballasts, and LED isn't an option, it is worth it to upgrade it. The electronic ones are more efficient, and the bulbs should last longer with them.
  16. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    During renovations I had the side door outside light fixture replaced. While the electricians were still around I hit the switch and the light didn't come on. I figured they had done a poor wiring job. Turns out - it was the light switch, which they had to replace. A rare occurrence, indeed.
    #16 RRxing, Apr 9, 2020
  17. Leadfoot J. McCoalroller
    6,824
    6,473
    Pennsylvania
    2018 Prius c
    LED conversions are nice, but they generally require that the host fixture is already set up for instant-start tubes, NOT rapid-start tubes.
    There are tubes on the market which will drop into an instant-start fixture and work immediately with no modification, but to the best of my knowledge all rapid-start fixtures will require ballast-bypass at a minimum.
  18. ETC(SS)
    6,493
    Ditch the fixture.
    Let hubby do it or tackle it yourself.
    Standard fixtures are....standard for a reason.
    Replacing it will be easy enough that even a hubster can do it - although you might want to put the decontamination chocolate porter off until he's back off the ladder.
    I'd strongly recommend LED bulbs if for no other reason than you know that you won't be dealing with the fixture again for quite a while.
    Good Luck!
    Pictures....
    (or it never happened!)
  19. NewHybridOwner
    NewHybridOwner Active Member
    607
    279
    W. Michigan
    I just relamped our newly rented church facility. Most of the ballasts were the old magnetic type, and some of them had actually leaked their no-longer-legal goo. Installed "Toggled" (strange name) direct-wire (rip out the old ballasts, even the electronic ones) LED tubes: 3000K for the nave, 4000K for the other areas. Some Home Depots have them, and Amazon may have them (although not so long ago there was a per-customer limit).
  20. ChapmanF
    15,094
    I haven't found that to be the case really.
    There was a period 15 years or so ago when my way of lighting a space like an unfinished basement was to go to, e.g., Menards, pick up a couple of their cheap two-tube shoplights (usually some would be on sale for $12 or so), return through the electrical aisle and pick up a couple electronic replacement ballasts and some decent Phillips tubes.
    The reason was that the ballasts that came with the fixtures would often have a "ballast factor" (not to be confused with "power factor", which is also a thing) as low as 0.65 or so. The ballast factor is the amount of light the tubes would produce compared to what was printed on them. A couple nice 3000 lumen tubes and you'd be expecting 6000 lm of light and getting only 3900, and wondering why the basement felt sort of dingy.
    Recycle the junky ballasts right away and put in even the basic electronic replacements from the next aisle over and the same fixtures and tubes suddenly lit the place up for real.
    The ballast is usually held into the fixture by one screw, and maybe an opposite corner that fits under a notch. It has about half a dozen wires that are color coded like the old one coming out. They only took minutes to change.
    But my fluorescent days are through. One thing I didn't like in the basement, which isn't exactly a vaulted space, was that the shoplights hanging down from the floor joists lowered the clearance even more.
    As it's unfinished and I wasn't too concerned with aesthetics, I bought some of the sticky 5050 LED tape, 5000 lumens per roll, cut it into sections about 12 LEDs long, and stuck three of those sections, spaced out, to the bottom edges of about every third joist. No more ducking for shoplights hanging down, and the light is way more even because it's not coming from just a couple places. The tape needs 12 volts, which can come (depending on the total length being powered) from an ordinary power-brick style supply, plugged into the ceiling outlet where the shoplights used to plug in.
    The LED tape does still like to stay cool, and wooden joists might not be the greatest heatsinks, so I got a roll of wide aluminum tape (as seen for ducts, etc.). Where each section of LED tape will go, a length of aluminum tape goes first (wide enough to fold a little way up both sides of the joist) and the LED tape is stuck to the aluminum. Seems to dissipate the heat just fine.
    And you know what, I've got no problem with the aesthetics the way it worked out.
    Trollbait and cyberpriusII like this.
