I can’t get any break....
Discussion in 'Newbie Forum' started by Garra671, Dec 13, 2020.
  1. Garra671
    Garra671 Junior Member
    44
    Wherever
    I just can’t believe what has been going on with this headgasket change....
    I just broke the f8/!:92’ing camshaft bearing cap.... and I don’t think you can buy it as a single item......
    I just.. idk anymore. I can’t believe this
    as well the camshaft is no longer in the TDC position it was before...
  2. ChapmanF
    15,662
    Ohhh, that's unfortunate.
    It's easy to forget what efficient machines threaded bolts are. Make a lot of downward force when you're cranking that wrench.
  3. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    There is a bright side to this. Those caps on the cam bridge are the same on every 1.8 2ZR engine. Whether it’s the hybrid in the Prius, or the Otto cycle in the Corolla, Vibe, or Scion. So if there is a pull it yourself yard near you, all you need is the cam bridge parts.
    PriusCamper likes this.
  4. ChapmanF
    15,662
    I see that from Toyota, the whole cam bridge (er, housing sub-assembly, camshaft) is available for sale, separate from the rest of the head, but the individual bearing caps aren't.
    That suggests that also if you go to a pick-n-pull, you'll want to bring home the entire "housing sub-assembly, camshaft" and all the bearing caps that come with it, as they were machined together and make a matched set.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
  6. Garra671
    44
    Wherever
    just to confirm what you’re saying.
    you’re saying the camshaft housing assembly and the caps.
    not camshafts. And housing assembly as well?
    I really hope the camshafts aren’t machined with the specific assemblies.....
  7. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    The cams from the Gen 4 engine I bought have lived the last 3 1/2 years in my Gen 3 head with no issue. The front cap, where the oil passage for the VVT solenoid is, and possibly the rear one have a replaceable bearing in them. The rest are machined to size.
  8. Garra671
    44
    Wherever
    Yeh. I’m more than likely going to need to buy the entire housing assembly. And probably all of the bolts..
    and wouldn’t be surprised if it doesn’t include the gaskets or bearings either.
  9. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    The other option to pull a part, is buy a reman head. Either from Toyota, or one of the major chain stores. Surefire PN# 2866A is the Gen 3 head. My neck of the woods it goes for $607.99 exchange, with a 1 year warranty.
  10. rjparker
    rjparker Tu Humilde Sirviente
    7,980
    4,724
    Texas Hill Country
    Buy some junkyard parts and a torque wrench on your way back.
  11. ChapmanF
    15,662
    Well, Toyota will sell camshafts separately, while they won't sell bearing caps separately from the housing they were machined with, so that kind of gives away the answer. The camshafts you've got should be ok in the replacement housing as long as they pass whatever thrust clearance and oil clearance (Plastigage) tests you find for them in the repair manual.
  12. Garra671
    44
    Wherever
    Camshaft housing assembly is about 300$ from what I’ve seen.
    Id imagine I wouldn’t need to buy an entire new cylinder head.
  13. Garra671
    44
    Wherever
    Trust me. I used a torque wrench. I set them too 20ftlbs. None of the others cracked. I’m assuming it was from the paper towel... under the cap.
  14. Garra671
    44
    Wherever
  15. ChapmanF
    15,662
    Yes, absolutely that's what it was. You can't go torquing them down in that condition, only snugging them enough to hold the cams tightly. When you torque a bolt like that, it exerts a very strong downward force on the cap.
  16. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
  17. Garra671
    44
    Wherever
    right? You scared me lol... I thought that stupid smart paper towel went from costing me 300+. Too 900+.
  18. Garra671
    44
    Wherever
    Yeh I know.... I just didn’t even think about it...
    I was reassembling and didn’t even think twice about the paper towel holding the cam..
  19. EastCanMan
    EastCanMan New Member
    NB, Canada
    Nobody mentions that you must coat cam shaft with an engine lube so that there is suction in the oil pump prior to torquing elsewise you will have zero oil pressure on startup and may never have. Plastiguage (as mentioned) caps and clean bolt holes, lightly oiling with thin oil to ensure proper torque specs. Caps could be fixed with retainer clips from copper easily but this is a BMW trick & Necessity.
  20. EastCanMan
    NB, Canada
    You also have to torque in 2 or 3 steps starting from middle and working outward so we don’t break things. Oh! Don’t forget the ‘pre-lube’ of cam journals and caps or else no oil pressure will result since the pump can’t pressurize when moving parts are dry! :)
