I can only start car with key in ignition but it is supposed to start with key in pocket
Discussion in 'Gen 2 Prius Main Forum' started by MilkyWay, May 2, 2017.
  1. MilkyWay
    MilkyWay Active Member
    819
    358
    23
    MI
    My other prius if the doors are locked and I walk up to it with key in pocket they open....this one I just bought does not.
    Also, my other prius if key is in my pocket car starts. I never put key in the ignition. This one I just bought you have to have key in ignition to start.
    Any common reasons this malfunctions? Hoping it is a bad fuse as I have seen this same problem in other priuses.
  2. JimboPalmer
    12,470
    6,869
    Greenwood MS USA
    The most common problem with this symptom is a dead Fob battery. CR 2032 3V battery
  3. MilkyWay
    819
    358
    23
    MI
    I can hit the key fob and doors lock/unlock
    49,601
    there are two versions, sks, and non sks. does it have the on/off button under the steering wheel?
    if it does, and the button is on, and it still doesn't work, it can be the fob battery, because it takes more power to use sks than just pushing the buttons.
    also, the 12v can be suspect.
    MilkyWay and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,518
    14,121
    Tampa, FL
    Also, I think the SKS fob has a silver logo and the non-SKS has a black log.
  6. bisco
    49,601
    which is confusing, because you can buy a black fob and program it for an sks car, but it will only work in the slot.
  7. MilkyWay
    819
    358
    23
    MI
    Sweet. If only all repairs were that easy. I pushed the key button in and could immediately start with key in pocket...Drivers door also open as I approach locked car.
    Thanks
    jerrymildred and bisco like this.
  8. bisco
    49,601
    pleasure. hey, even a blind squirrel finds a nut once in awhile.:p
  9. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Something else to consider Milkyway, if you are not scheduled to drive either cars for extended periods of time with the SKS feature, good counsel is to turn the system off to avoid unnecessarily draining the 12v battery. If the SKS system is on/armed it's constantly consuming voltage from the 12v battery, not oodles and gobs mind you but no sense straining the system if you don't have to.
