I can't get my car to run. Please help!
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 6, 2024 at 6:13 PM.
  1. Prius92
    Prius92 Member
    400
    99
    Iowa
    Got the hybrid battery done. Get everything installed and there are still throttle body error codes.
    They are:
    P0121
    P0122
    P0222
    P2135
    Which are:
    Throttle position sensor rationality.
    Difference between VTA1 and VTA2 voltages less than 0.8v, or more than 1.6v for more than 2 seconds.
    Throttle position sensor 1 low voltage.
    Output Voltage of VTA1 0.2v or less for 2 seconds or more.
    Throttle position sensor 2 low voltage.
    Output Voltage of VTA2 1.75v or less for 2 seconds or more.
    Throttle position sensor range check (correlation)
    Difference between VTA1 and VTA2 0.02v or less for 0.5 seconds or more.
    I went to the junkyard and got another complete throttle body, and it STILL does it.
    I checked for 5 volts at the TPS connector and it's there.
    My 12v battery is only 11.4 volts. Could a low battery be doing this?
  2. PriusCamper
    PriusCamper Senior Member
    11,134
    4,534
    Pacific Northwest, USA
    What kind of code reader are you using? Are you sure your code reader has a code library for hybrid vehicles? Some of these codes don't make sense?
  3. Tombukt2
    Tombukt2 Senior Member
    9,339
    1,635
    Durham NC
    Yeah you need to check your code reader and make sure that it's up to snuff and yes you need 12 volts really I mean some components will work down to 9 volts but which ones and all that who knows at least I don't.
  4. Tombukt2
    9,339
    1,635
    Durham NC
    When my throttle body did go bad in either Gen 2 or 3 I didn't have all these codes
    PriusCamper likes this.
  5. Prius92
    Prius92 Member
    400
    99
    Iowa
    Using a bluetooth code reader with the Dr. Prius App.
  6. PriusCamper
    11,134
    4,534
    That app has most of the codes, but not all of them... May try: "Car Scanner (ELM)" app to see if there's anything else and then we can work on the codes you do have some more.
    Brian1954 likes this.
  7. PriusCamper
    11,134
    4,534
    Yeah... Same with me...
  8. Prius92
    Prius92 Member
    400
    99
    Iowa
    After leaving the car off with the 12v disconnected for a couple hours, I still get 3 codes before even starting it.
    P0122, P0222, and P2135.
    But here's the kicker...I get these codes if the TPS is connected or not.
    I took ALL the plugs out of the computers behind the glove box to check for damage and did not see any.
    I checked the ground between the connector for the TPS and several ground points around the underhood and all were good. So it's well grounded.
    I plugged the TPS back in, and loaded the sensor data, the computer is seeing the TPS change if I manually rotate the throttle shaft.
    It also sees the accelerator pedal as well.
    The other weird thing? I accidentally disconnected the 12V battery with the ignition on and it was...still on. Does the traction battery kick in if the 12v is disconnected from ground?
  9. Tombukt2
    9,339
    1,635
    Durham NC
    If the car is on ready then the DC to DC converter is putting out output to the 12 volt to keep it charged but if you break the ground connection I would think that might mess up the 12 volt charging that should be going on but I'm not sure it wouldn't necessarily turn the whole car off but yeah maybe so I'll have to go out and try it if you break the 12 volt ground then pretty much everything that's 12 volt in the car should go off which is pretty much everything except orange cable things. Which there are not that many so you must not have broken the ground good enough or something
  10. PriusCamper
    11,134
    4,534
    The 12v is designed to power up all the systems and once the high voltage battery is on the 12v does nothing but sit there and get a near 14 volt trickle charge.
    I'm thinking you need to replace or fully charge the 12v battery because a weak 12v creates all kinds of malfunctions when it tries to power up all the car's systems with lower than the needed voltage.
    Also you haven't explained what the car's symptoms are beyond the error codes. Does the car shift into neutral at least? Does the car go into ready mode? Do you have specific warning lights? Or is the dash blank? We need all these details to tell you what to focus on next!
    And lastly, if none of the above works, I think something is wrong with whatever you mean by "got the hybrid battery done." Please clarify and maybe double check the 100+ connections that all have to be done right for it to truly be "done."
  11. Prius92
    Prius92 Member
    400
    99
    Iowa
    Car runs about 3 seconds then shut off. Yes, goes into ready mode, all systems go.
    Gas in the tank is a year old, which I'm sure doesn't help. But that would not cause a throttle body DTC.
    I can use my OB2 reader and manipulate the throttle shaft by hand and see both position values change, so the connection to the computer seems fine.
    The ground is good, the 5v reference signal is good.
    The DTC's come up as soon as you turn the ignition on, and oddly they come on even if the throttle position sensor is connected or not.
    Unless somehow clearing the codes via the app as well as disconnecting the 12v battery does not actually clear those DTCs.
  12. PriusCamper
    11,134
    4,534
    That's just the hybrid battery spinning the engine and the engine not starting... If you try too many times you'll need to charge up your battery pack via a grid charger or via charging each individual module to try again.
    Was the engine working before you did what you describe to make the hybrid battery "done?" And why won't you describe the details of the work you did on the hybrid battery?
  13. Brian1954
    Brian1954 Active Member
    895
    333
    South Central PA, USA
    Based on your description, I think the codes you are seeing are history or permanent codes and not active codes. Download the Car Scanner ELM app as suggested in post #6.
    Fresh gas in the tank would be a big help.
  14. Prius92
    Prius92 Member
    400
    99
    Iowa
    The hybrid battery had a cell that was bad, I swapped it out, charged each cell at 2amps for 20minutes.
    It's all good per Dr. Prius. Nothing out of whack. 59% state of charge.
    Permanent or history DTC's should be cleared when clearing them via the ELM app and disconnecting the 12v. Only codes that persist after that (as far as I know) are SRS and other safety system codes.
  15. ChapmanF
    15,789
    I dun᠎no, they make sense ok to me. You can find more about them all in this post. (That post, and the drawing below, are about the gen 3 Prius, but the main details are the same for gen 2.)
    The throttle position sensor is in fact two redundant sensors, producing two voltages, VTA1 and VTA2. Both voltages increase with increasing throttle opening, but by design they are not identical (therefore, if they were ever somehow shorted together, the ECM would know something wasn't right). You can see there is both a 1.11 V constant offset and that also VTA2 has a steeper slope.
    In gen 2 the sensing is done with two potentiometers instead of magnets and Hall sensors, but the sensor outputs keep the same relationship, with the offset and the different slopes.
    So the ECM can sanity-check the throttle sensor in various ways. It can give you a code that's just about VTA1 or VTA2 if one of those is clearly out of range (reading zero, say). Or, if neither one is clearly out of range, but the relationship between them is not the right VTA2 = (VTA1 + 1.11) ÷ 0.8, you can get a code about miscorrelation between the two.
    In any of those cases, the ECM does not trust the throttle position sensor, so it's going to be very balky about using the engine or driving.
    It is possible to have intermittent faults, so that sometimes both readings might look ok to you. If you have a scan tool that can retrieve freeze frames, you should be able to see the Throttle Position #1 and #2 voltages saved at the times the codes were set—as well as other things, like the engine load and target throttle position at the time—which could all help you spot which value looks out of kilter and get you thinking why.
    Edit: VTA2 = (VTA1 + 1.11) ÷ 0.8 isn't the exact relationship across the whole range, as you can see VTA2 hits its maximum voltage a bit earlier than VTA1 does, and bends over flat after that.
    #15 ChapmanF, Aug 6, 2024 at 10:47 PM
  16. Brian1954
    895
    333
    No, history and permanent codes will NOT clear during a disconnection of the 12v battery or clearing with a scan tool. You need an app that shows the status of the codes (active, pending, history ) that you have. I know that the Car Scanner ELM app does show the code status. The app is free, so try it and see what you got.
    Edit: All 4 of the codes you listed are retained in memory until the problem is fixed and the car confirms that indeed it is fixed. So I think all 4 of the codes are history codes and you do not need to be concerned with them.
    I believe that you have other active codes that the Dr. Prius app is not reading. The Car Scanner ELM app is a more capable scan tool for reading DTCs.
    #16 Brian1954, Aug 6, 2024 at 10:48 PM
  17. PriusCamper
    11,134
    4,534
    I've found that to be true with Gen3 Prius (2010-2015) but I've never had that problem with Gen2 Prius (2004-2009). I suspect Gen2 Prius doesn't have the (active, pending, history) feature. It just has codes that clear when you disconnect the 12volt for a few minutes until the car finds the same codes again.
