I can't open rear door by fob
Discussion in 'Gen 3 Prius Main Forum' started by RastinoSLOVAKIA, Feb 23, 2023.
  1. RastinoSLOVAKIA
    RastinoSLOVAKIA Junior Member
    Slovakia
    I can't open one rear door and window by driver switch too
    51,141
    Sounds like a loose connection
    RastinoSLOVAKIA likes this.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,040
    775
    Virginia, USA
    But the window works at the rear door, correct? I did some research on that since I have a similar problem -- can put rear window DOWN from driver's door but not UP.. I think I recall that generally the issue is in the switch assembly at the driver's door. Personally, I just put a wide piece of clear tape over the driver's door rear switches.
  4. dbstoo
    dbstoo Senior Member
    1,380
    745
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Check the following "safety" settings
    1) is the child lock "on" for that door? If so, it may cause some of the symptoms. Child lock is on the edge of the rear doors, designed to keep kids from opening the door while the car is moving.
    2) Is the "window lock" activated? That's a button on the driver's door.
    3) Opening the rear door via FOB. On mine I have the car settings arranged so that the rear doors unlock when I press the "unlock" button twice in succession.
  5. RastinoSLOVAKIA
    Slovakia
    from the back seat, the window works properly and the door opens mechanically
  6. RastinoSLOVAKIA
    Slovakia
    1. ok2. ok 3. second rear door open by fob correct
