I can't start my 2008 Prius without inserting the key into the slot, Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RichardSam, Jan 7, 2015.
  1. RichardSam
    RichardSam Junior Member
    17
    Abuja, Nigeria
    I bought this second hand 2008 Prius some few months ago. I can't start my 2008 Prius without inserting the key into the slot. I want to start the car with the key in my body, how do i do it? I have changed the fob battery, the key is doing every other thing, but i must insert it into the slot before i can the start the car, help!
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    On the gen2 there's a button under the dash that turns the srs on and off it must be turned off.
    Got an owners manual?
    Asdastro and glrooney like this.
  3. RichardSam
    17
    Abuja, Nigeria
    I have owners manual, i have read it from the 1st to the last page. I know about the button under the steering, i will turn it off. I forgot to mention that the car does not response when i press the panic button on the key fob. The Smart entry is working, but the start does no start if i don't insert the key in the slot.
  4. RichardSam
    17
    Abuja, Nigeria
    I have turn
    I have turn the sks off, but the car did not start without inserting the key into the slot
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    If the smart entry is working then it's not the button under the steering wheel. So we can throw that out.
    That the panic button doesn't work seems strange. Sounds like the fob itself is encountering problems.
    Another possibility is who you bought it second-hand from. If you know and trust the source then stop reading now.
    If the car was crashed and rebuilt, it's possible that not all the wires got reconnected correctly. If it was damaged enough, it's possible that the interior fob sensor isn't working. The Prius is a very sophisticated and technological car; there are several reports here on Priuschat of people purchasing refurbished Prii that were not put back together well.
  6. RichardSam
    17
    Abuja, Nigeria
    I have turn
  7. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    On the back of the FOB is the Toyota logo Silver..
    Black logo FOBs require inserting to the dash..
  8. RichardSam
    17
    Abuja, Nigeria
    The Logo on the Back of the fob is silver, which means the sks should start the car without inserting into the slot
  9. bisco
    51,155
    you may need a new fob battery, or a new 12 volt battery.
  10. RichardSam
    17
    Abuja, Nigeria
    I have already changed my 12 volt battery and fob battery
  11. bisco
    51,155
    oh boy.(n) can you unlock the door with the key in your pocket by touching the door handle?
  12. RichardSam
    17
    Abuja, Nigeria
    Sure, i can do all that, i can unlock the door with the key in my pocket
  13. bisco
    51,155
    so the sks works on the doors, but not the ignition. i guess i would test the battery voltage's, simple and quick before moving onto something more complicated.
  14. RichardSam
    17
    Abuja, Nigeria
    I have just tested the 12v Battery, it is resting 12.78 volt
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Does the fob show a nice bright red led when you
    Push the button.
    And you keep saying i turned the sks button under
    .The steering OFf.
    It must be on.
  16. bisco
    51,155
    that's a good number. did you let it sit for a few hours so the surface charge would dissipate?
  17. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Important question... Did it ever let you start the car without the FOB in the slot?
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    I think your panic button on your fob may be stuck on. I would take the fob apart and clean it with alcohol and a Qtip. Try to touch the microswitch with the fob apart and see if the panic button makes a clicking sound.
  19. RichardSam
    17
    Abuja, Nigeria
    I bought the car second hand, so i have never started the car with the FOB in my pocket
  20. RichardSam
    17
    Abuja, Nigeria
    I have off the car for about 4 hours, before i tested the 12v battery
