I change the gas engine on my2010 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mohammad Ghannam, Dec 2, 2016.
  1. Mohammad Ghannam
    Mohammad Ghannam New Member
    US
    And all the lights are on at the dashboard including the check hybrid light, and the gas engine won't start,,
    Any body can help please
  2. ETC(SS)
    6,556
    Good Morning!
    We're going to need a few more details including why you posted "I change the gas engine on my 2010 Prius"
    Codes.
    Vehicle History.
    Good Luck!
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    You need techstream
    49,504
    is there gas?
    did you disconnect the orange high voltage connector, and not complete the proper reconnect sequence?
    Mohammad Ghannam likes this.
  5. Mohammad Ghannam
    US
  6. bisco
    49,504
    after you close the connector, you have to slide it down. i think there is a youtube video.
  7. tankyuong
    1,555
    660
    Central MO
    And reset by pressing ignition on and off 3 times
  8. Mohammad Ghannam
    US
    When you press the ignition switch 3 times do you step on the gas pedal or break ?
  9. tankyuong
    1,555
    660
    Central MO
    I believe with brakes
    Rebound likes this.
  10. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Prius won't fully start without foot on the brake pedal.
  11. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    did you finally get your prius to start? I also changed my engine last week and have not been able to get it to start
