I changed the spark plugs in my '08 today, largely without drama
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by egg_salad, Jun 12, 2018.
  1. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Car has 95k on it, I figured it was time. Judging by the (likely original) plugs I took out, they probably could have lasted another 20k easily. But hey, I already had the parts in hand, so why not?
    Job is pretty straightforward, although if I ever have to do it again I will buy a 3/8" x 6" wobble extension, which would have helped greatly, especially on the #4 plug.
    RobH likes this.
  2. Mendel Leisk
    38,887
    What size of socket is second gen, just curious. FWIW 3rd gen is 14 mm or 9/16". Also, the cowl and all above needs to come off, a bit frustrating.
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    I've got 130k on my original plugs. Since I know they'll last at least that long, I may as well take the replacements off the shelf in the garage and put them in. Really don't expect to keep the car another 12 years...
    Raytheeagle likes this.
  4. egg_salad
    545
    426
    Las Vegas, NV
    It's a 5/8" spark plug socket. Might be the placebo effect, but the slight stumbling effect that I felt when the engine was stopping seems to be mitigated now.
  5. JC91006
    16,494
    8,404
    Yes I believe that's placebo too
  6. egg_salad
    545
    426
    Las Vegas, NV
    If that's the case (and you're probably correct that it is) I'm fine with that, too.
    A man can dream :)
  7. JC91006
    16,494
    8,404
    I changed my spark plugs a while back, thinking I would regain lost mileage. Initially it worked wonders....then I started to drive like myself again and all the placebo effect went away
  8. Mendel Leisk
    38,887
    Anyone ever check the valve clearance? Or is that just crazy talk, with the shims? I really liked the screw adjuster style. Usually they loosened, and when you tightened them to spec you could feel a slight improvement.
    The shim style tend to be very stable, maybe best left alone. Probably no one touches them: it's impractical to DIY, and dealership would be too expensive.
  9. JC91006
    16,494
    8,404
    It's crazy talk on a gen2, I understand it to be as difficult as swapping the engine
  10. Patrick Wong
    18,200
    6,479
    Checking isn’t difficult; however adjustment is since the camshafts have to be removed. I checked the clearance on my 2001 several years ago and the valves measured in spec or slightly loose.
