I did 999 mpg again ...and now uphill
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by brian brooks, Jan 31, 2013.
  1. brian brooks
    brian brooks Junior Member
    17
    A couple times this month I did 999 going to work my 8.5 miles but is mostly downhill, but last night going mostly uphill again I did 999 mpg. The weather was 51 degrees and traffic was going at 55mph so i was able to stay in EV and the engine never turn on, I have the lower grill blocked and drove sensible.
    51,154
    sweet!!! it's the best, isn't it? you should plug in the jurassic park model and see what the elevation change is.
  3. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    It's fun to hear others discovering that.
    For me, there's a climb out of the river valley I have to do routinely. Traffic isn't always moving that fast during rush hour, but there are times I've hit that segment of highway traveling along at 55 mph. The Prius handles it just fine at that speed while climbing using only electric.
    What I actually get a kick out of more is the steep hill climb from my home. You have to turn onto a 45 mph road from a dead stop. Being able to do that in EV is sweet, which is so much more appealing than any vehicle would an engine does it. Just smooth & silent. No gear shifting or combustion roar.
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) I'm sending a note to oil producers. Effective immediately, I'm cutting back. My one week old Prius Plug-In achieved it's first 999mpg trip to work this morning. My commute is 9.8 miles, mostly interstate, cruise control set at 60mph. Pleasantly surprised. I was debating whether to run a line so I can recharge at work. My thoughts, if it makes sense, do it, and I will. I switched from wanting a Prius 5, to the PIP, at the last minute. Smart move. My confidence is high. I plan to place a bet on the Super Bowl. My money will be on the San Franscisco 99ers.
    R3VOLTN - and I "ain't" going back
    retired4999 likes this.
  5. bisco
    51,154
    well done! this is impressive, since the guy in another thread can't seem to get his pip out of the garage without the engine starting.:rolleyes:
    rogerv, retired4999 and SuperMookie like this.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Two all EV trips this morning 2.7 miles each way to and from coffee, 5 degrees f so 5.4 all EV with about 5.3 EV left when arriving home! :)
  7. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    Brian, just keep in mind the 999mpg is not at all accurate. That is just as high as the screen can show.... Much closer to infinity actually as no gas was used. (Yes I know nothing is close to infinity except infinity...:LOL: ). But I love gliding around town in EV mode and see people stare at the car because they don't hear the roar taking off from a stop light!
  8. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    U take the noise maker off?
  9. SLOW_RR
    SLOW_RR Member
    155
    84
    No, but next Summer I may play a recording of this old girl throttling up to notch 8 on the hill at the museum...:ROFLMAO:
    That ought to really confuse them!
  10. lensovet
    2,615
    496
    Burlington, NJ
    no, but a regular Prius will spin up the engine when you pull away from a stoplight, and it's much noisier than the noisemaker.
  11. Gaudete
    Gaudete Junior Member
    71
    I've had trouble keeping my PiP in EV mode w/o the ICE kicking in when I tackle a fairly steep uphill in the morning. Any recommendations?
  12. Gaudete
    71
    I should add that the PiP is kept in an unheated garage, where it probably drops to about 30 degrees overnight. The ICE doesn't kick in immediately however - only once I start to ascend the hill. If I'm really careful, and crawl up the hill at about 10 mph, I can usually keep the ICE at bay. But if I press the accelerator any more than that, and get up to about 30 mph, the ICE pops on. (Mind you, I steer clear of the "power" end of the hybrid indicator bar.)
  13. john1701a
    12,797
    5,280
    57
    Just Drive It.
    Winter isn't going last forever and engine warm-up doesn't take as long as it seems.
    Summer changes the equation anyway. You'll be able to climb the hill then.
    Much more power can be extracted from the battery when it's warm outside. It's also possible when both the cabin is warm and the battery itself. So if you can't wait for the warm season, you can try that now.
  14. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    take a good run at the hill, then put the car in neutral and glide. OR. Park the car overnight on top of the hill.
  15. lensovet
    2,615
    496
    Burlington, NJ
    I don't think you can do much other than setting the end charge timer to finish just before you leave
