I Feel so Dirty: Folder Names with "_" in Front
Discussion in 'Fred's House of Pancakes' started by TonyPSchaefer, Mar 31, 2010.
  1. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    So I have an iMac now. I got it for Christmas. There's very little that I don't like about it. But there's something that really bothers me: I really like having the folder sort to the top of a list in Finder. This is a carry-over from Microsoft Windows where the folders are almost always on top.
    So I've resorted to what I have always considered a technological sin against mankind and all that is holy. I start my folder names with an underscore ( _ ). I have been to two separate Apple stores and have talked this over with the Geniuses there. The only way they could get the folders to sort to the top is to sort the Finder window by type. This accomplishes one thing but screws up the alphabetical sorting of the files.
    Perhaps I'm being too picky. Perhaps I really do want the best of both worlds. Perhaps I would get accustomed to the folders being sorted just like the files. But for right now I'm using the underscores. I don't like that I'm resorting to such crass abuse of the sorting hierarchy, but it's what I've become.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I guess you could start your folders off with other chars that start earlier, like A or 1... But, that looks just as bad or worse.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    You're unbelievable Tony. I never thought you would stoop so low!!
    :confused:
  4. thegreatll
    thegreatll New Member
    oviedo
    you make me sick
  5. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    You gotta do what you gotta do
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Start each folder name with !@#$%. :roll:
  7. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I have lost all my faith in you Tony. For shame.
  8. dogfriend
    7,512
    1,185
    Carmichael, CA
    Make Finder sort by type with Folders at top
    This link explains how to modify Finder.app so that folders will be listed first when listing "By Kind". It is supposed to work with Leopard (10.5). I haven't tried it, but I found the page by doing a Google search. If it works as advertised, you won't need to use "_" or any other prefix to get folders to list before files.
  9. b2j2
    b2j2 Member
    46
    Edgecomb, Maine
    Try a space (" "). Works in OS 10.4.11 and earlier.
    Mac user since 1984
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    If an underscore make you feel dirty, use a dollar sign. :)
    I have always used ~ in DOS or Windows.
  11. TonyPSchaefer
    14,816
    2,498
    66
    Yeah. Thanks.
    This is the only semi-viable solution the Apple Geniuses could provide. The thing is that I don't always want files sorted by type. I rarely sort that way and only when I can't find it alphabetically.
  12. Tom183
    Tom183 New Member
    652
    65
    Maine
    As with all technology, the weak link is the thing in front of the monitor...
    This is why databases never allow a "miscellaneous" category, and why everything at work is either "top priority" or "top priority".
  13. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    You can also color-code folders and files in Finder.
  14. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Now start making folders with a "." (period) as the first character.
  15. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    AND this my friends.... is the biggest complaint he could come up with for his mac.
    Kind of like going from a Ford to a Toyota huh Tony. ;)
  16. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    Welcome to the Good side!
    That is one of the few annoyances with Mac OS X. I think it's a direct result of the Unix underpinnings (and so I would also avoid starting a name with '.').
    Mac user since 1989, Apple user since 1981, back when 48 KB was all the RAM you would ever need. Until '83, when 64 KB was all the RAM you would ever need.
  17. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Just run Windows on your Mac.:)
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    My Linux systems running gnome desktop float the folders to the top just fine, and keep everything in alphabetical order at the same time.
    Don't blame Unix for the bad Apple user interface. One of the nice things about Unix and Linux is that the windows manager, windows decorator, and shell are all modular. You can use whatever one you want. Apple wrote their own to make it look like the traditional Mac interface, but in typical Apple fashion they handcuffed the user to it so that you are forced to do it their way.
    Tom
  19. dogfriend
    7,512
    1,185
    Carmichael, CA
    Not exactly true, there are 3rd party Finder replacements available. Pathfinder is one of them.
    Path Finder 5 by Cocoatech
  20. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Well, you could always just do everything in a Terminal command-line
    environment like the real men do, and when you want to see your
    directories you just do "ls -d */". If you want to get fancy, you
    can alias "lsd" to "ls -lF \!* | egrep /$", csh style, to save typing.
    Seriously, I would heartily *disrecommend* using spaces, dollarsigns,
    leading periods, asterisks, etc in any filename. They are anathema to
    unix shell environments, and the spaces-in-filenames thing especially
    screws up websites to which such files are uploaded.
    Eventually you may get to the point where you want to do
    "defaults write com.apple.Finder QuitMenuItem -bool yes"
    and just splat-Q the silly thing shortly after booting up, and
    hang out in operating environments that are much more versatile.
    _H*
