I Found TSB-0067-08 - Noise From Auxiliary Port With External Device
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by mrblaise, Jun 13, 2008.
Thread Status:
Not open for further replies.
  1. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    Here's the new Toyota Service Bulletin for everyone who has been experiencing noise when using the auxiliary port in your 2008 Prius. Hold down the control button and double click on the link and it will open up in Adobe format.
    [​IMG] TSB-0067-08.pdf (461.4 KB)
  2. racerbob
    racerbob Member
    138
    S Florida
    Link doesn't work. Site requires log on.
  3. mrblaise
    2,248
    525
    Southern California
    Here's the text if you can't make the link work. This should be good enough to show the service tech.
    T-SB-0067-08 May 21, 2008
    Noise from Auxiliary Port with External Device
    Service
    Category Audio/Visual/Telematics
    Section Audio/Video Market USA
    Applicability
    YEAR(S) MODEL(S) ADDITIONAL INFORMATION
    2006 – 2008 4Runner, Prius, RAV4
    2007 Camry, Camry HV, FJ
    Cruiser, Yaris
    2007 – 2008 Solara
    TSB SUPERSESSION NOTICE
    The information contained in this TSB supersedes TSB No. AU004-07.
    • Applicability has been updated to include 2008 model year 4Runner, Prius, RAV4, and Solara.
    • Parts Information has been updated to include a clarifying illustration.
    TSB No. AU004-07 is Obsolete and any printed versions should be discarded. Be sure to review the
    entire content of this service bulletin before proceeding.
    Introduction
    Some customers may notice noise in the auxiliary mode of their audio system when using an MP3
    player or other external audio source connected to the 12V power port of the vehicle. An improved
    auxiliary port and in-line filter has been developed to improve this condition.Use the repair procedure
    below to install the new in-line filter and auxiliary port.
    Required Tools & Equipment
    SPECIAL SERVICE TOOLS (SST’S) PART NUMBER QTY
    Plastic Pry Tool Set* 00002-06000-01 1
    * Essential SST.
    NOTE
    Additional SSTs may be ordered by calling SPX/OTC at 1-800-933-8335.
    © 2008 Toyota Motor Sales, USA Page 1 of 7
    T-SB-0067-08 May 21, 2008 Page 2 of 7
    Warranty Information
    OP CODE DESCRIPTION MODEL TIME OFP T1 T2
    4Runner 0.3
    Camry (CBU) 0.2
    Camry (NAP) 0.2
    Camry HV (NAP) 0.2
    FJ Cruiser 0.2
    Prius 0.3
    RAV4 0.4
    Solara 0.2
    Yaris Hatchback 0.2
    AU7002 R & R Stereo Adapter Assembly
    Yaris Sedan 0.2
    Combo A Install In-line Filter & Adapter
    Assembly ALL 0.1
    86190–##010 91 99
    APPLICABLE WARRANTY
    • This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for
    36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
    • Warranty application is limited to correction of a problem based upon a customer’s specific
    complaint.
    T-SB-0067-08 May 21, 2008 Page 3 of 7
    Parts Information
    Figure 1.
    1 Adapter Assembly, Stereo (Mini Jack)
    2 Wire, Condenser (Wire Harness)
    3 Condenser (Noise Filter)
    4 To Existing Vehicle Wire Harness (4P)
    ITEM MODEL PREVIOUS PART
    NUMBER
    CURRENT PART
    NUMBER PART NAME QTY
    4Runner 1
    Camry (CBU)
    86190-53010
    Camry (NAP) 86190-06010 1
    Camry HV (CBU) 86190-53010 1
    Camry HV (NAP) 86190-06010 1
    FJ Cruiser 1
    Prius 1
    RAV4
    86190-53010
    86190-48010
    Solara 86190-0C010 1
    Yaris Hatchback 86190-52010
    86190-12020
    Yaris Sedan 86190-53010 86190-48010
    (Mini Jack)
    2 All N/A 86237-33010 Wire, Condenser (Wire
    Harness) 1
    3 All N/A 86516-33020 Condenser (Noise Filter) 1
    NOTE
    Items 1, 2, and 3 are needed for all vehicles. Item 1, Adapter Assembly, Stereo (Mini Jack), MUST be
    ordered according to specific model. Items 2 and 3 are the same for all models listed.
    T-SB-0067-08 May 21, 2008 Page 4 of 7
    Repair Procedure
    1. Remove the existing auxiliary port terminal from the vehicle.
    Refer to the Technical Information System (TIS):
    • 2006, 2007, or 2008 model year 4Runner Repair Manual, Audio/Visual/Telematics –
    Audio/Video – “Audio/Visual: Audio Terminal: Removal”
    • 2007 model year Camry or Camry HV Repair Manual, Audio/Visual/Telematics –
    • 2007 model year FJ Cruiser or Yaris Repair Manual, Audio/Visual/Telematics – Audio/Video
    – “Audio/Visual: Stereo Jack Adapter Assembly: Removal”
    • 2006, 2007, or 2008 model year Prius Repair Manual, Vehicle Interior – Interior
    Panels/Trim – “Instrument Panel: Rear Console Box: Removal”
    • 2006, 2007, or 2008 model year RAV4 Repair Manual, Vehicle Interior – Interior
    Panels/Trim – “Instrument Panel: Lower Instrument Panel: Removal”
    • 2007 or 2008 Solara Repair Manual, Audio/Visual/Telematics – Audio/Video –
    Figure 2.
    1 Existing Auxiliary Port
    2 Console Box
    3 Vehicle Wire Harness (4P)
    T-SB-0067-08 May 21, 2008 Page 5 of 7
    Repair Procedure (Continued)
    2. Install the revised auxiliary port, wire harness, and noise filter.
    Tape the noise filter to the back side of the trim panel near the auxiliary port ensuring the filter
    does NOT touch other parts or the wiring harnesses in the vehicle.
    NOTE
    Steps A – D are generic installation instructions. The 2007 model year Camry installation is
    provided as an example.
    A. Connect the vehicle wire connector (4P) into the filter, and connect the filter wire connector
    (8P) into the filter.
    Figure 3.
    1 Filter Wire (8P)
    2 Filter
    T-SB-0067-08 May 21, 2008 Page 6 of 7
    B. Secure the filter to the vehicle wire harness using wire ties.
    Figure 4.
    1 Filter 2 Wire Ties (x2)
    C. Install the NEW auxiliary port to the console box.
    Figure 5.
    1 Auxiliary Port 2 Console Box or Center Console Box
    T-SB-0067-08 May 21, 2008 Page 7 of 7
    D. Connect the filter wire connector (8P) into the NEW auxiliary port.
    Figure 6.
    1 Console Box
    2 Auxiliary Port
    3 Filter Wire
    3. Reassemble the vehicle in reverse order of disassembly.
    4. Verify proper operation and that NO noise persists in the auxiliary mode of the audio system.
  4. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
Thread Status:
