I got a hot @ss!
Discussion in 'Gen 3 Prius Main Forum' started by bighouse, Dec 9, 2009.
  1. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    We've had an unusual cold spell here in California the last two days. This morning, with temps in the low twenties, I decided to hit that heated seat button below the center console.
    ahhhhhh.....nice.
    I did notice that it warms up, then cools down, warms up, then cools down...is that normal behavior for heated seats? I've never had them before.
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I would have to confirm that's the way mine works as well.
    It appears to cycle which is really nice. In other cars with variable selections you have to turn them down, but this seems to cycle so I am assuming that's why we only have a ON or OFF functionality.
    All in all they heat quick and are quite nice....Remember to baste while turning! ;)
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    My wife works that way too. I think it may be her age.
    Tom
    5 people like this.
  4. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
    Yeah, our other car (embarassingly, an '04 Yukon), has heated seats that have many settings for both the seat only, or the seat plus the seat back. Low, medium, and high for each. But I am pretty sure its a constant heat rather than a cyclic thing.
    I am sure the way the Prius is set up is to save juice. Once you are up to temperature, you just need to maintain. Just like driving speed.
  5. firebatt
    firebatt Junior Member
    Twain Harte,CA
    Like the earth your seat cycles warm and cool. My 2003 Acura and GMC PU do the same. Enjoy!
  6. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
  7. goingreen23
    goingreen23 New Member
    28
    NM
    Mine's the same way... warms up, then cools down....:)
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  9. going red baby!
    610
    96
    Los Angeles
    Did you use that line on that "lesbian"? :D
    I pulled my panties down silly. I don't understand why I have an "opposite" tan line though...
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    LMAO! I thought it was just hair. :bolt:
  11. DavidA
    2,328
    1,812
    Chicago western burbs
    A...hem...
    Getting back to the thread, my hot butt tonight at 8 degrees F on the way home was nice, although with only a 1.5 mile commute, it wasn't long enough to experience the heater recycling. Also, has anyone noticed the ice melting off their side mirrors? Supposedly, the mirrors are heated up when the seat heaters are on.
  12. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Interesting. On the Gen II, the side mirror heaters come on when the
    -- I almost hate to say it -- rear hatch glass defroster is turned on.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    Switched on or excited?
    (If I didn't say it Tom would have!)
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That is why I tinted my back window. That kind of activity should not be subject to public viewing...
    I never liked heated seats much. The ones in my friend's BMW get way too hot and burn my tush. Maybe I just don't have enough insulation?
  15. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I had heated seats on my Volvo and never used them either.
    I think a more plausible explanation of why you and I don't like heated seats is that our @sses are naturally hot (they're real and they're spectacular).
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    As usual Boo, I am inclined to agree with you my friend. :)
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    seats run on a on/off cycle like 10 on/ 5 off or something like that. it has been in single digits here for the past 4 days (normal low is the mid to upper 30's) so ya, its been real nice.
    current temp 10.8º
  18. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The seats aren't on any set cycle. There's a thermostat built-in to the heating element to engage up until a certain temp, then shut off. This allows the unit to be flexible in a wider range of temperatures - i.e. still be effective in colder weather with a longer "ON" cycle, and not overheat or burn the occupant in "warmer" weather with a shorter cycle.
  19. hill
    8,167
    I read the OP's title & started to report it to the ops
    :p
  20. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    David you need to turn on the Rear Defogger to get the side Mirrors to Warm...They are NOT controlled by the seat warmer switch.. ;)
