I got my fin on crooked
Discussion in 'Prius v Accessories and Modifications' started by Kayem, Sep 10, 2013.
  1. Kayem
    Kayem Junior Member
    So am I screwed?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You mean sharkfin antenna?
    No, take a piece of fishing line between two rods or dowels and "saw" at the double sided foam tape used to stick the antenna on.
    Once you get it off, clean the old adhesive off. Then you'll need to buy some double sided foam tape to remount the antenna. Buy the exterior trim rated one from 3M and trim it to fit the base of your antenna before remounting your antenna.
    Many people use the blue low tack painters tape to mark the position of the antenna to make sure it goes on straight.
    SCH-I535
    ursle likes this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    That's a drag!
  4. Diver Allen
    Diver Allen Member
    66
    27
    Cincinnati, OH
    2013 Prius v wagon
    I think it will make your Prius go in circles.
    jae and xliderider like this.
  5. KK6PD
    4,003
    944
    118
    That happened to the Bismark.
    Then the Brits promptly sent her to the bottom!
    However not before losing the H.M.S Hood and most of her crew!
